12-15-2014, 09:44 | #17 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: Iran < Milad.B >
Member: 1784663 Status: Offline Sonork: 100.1618770 Thanks Meter: 62 | HUAWEI Y530-U00 Done Quote:
The Following 2 Users Say Thank You to UNKNOWN GSM For This Useful Post: |
12-15-2014, 11:07 | #19 (permalink) |
Member: 1784663 Status: Offline Sonork: 100.1618770 Thanks Meter: 62 | all huawei phones supported all we need that language table must available on phones framework then we can active it using zzkey just by 1 click itsnt depending on os version or cpu or any thing els Last edited by UNKNOWN GSM; 12-15-2014 at 11:14. |
The Following User Says Thank You to UNKNOWN GSM For This Useful Post: |
12-15-2014, 11:14 | #21 (permalink) |
Member: 1784663 Status: Offline Sonork: 100.1618770 Thanks Meter: 62 | this phone is supported fully first root the phone just select : Huawei android adb and then select on other tab Huawei android adb autodetection2 MTK... dont need to select any model!!! just do what you need |
12-15-2014, 12:46 | #22 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | test on g630-u10 but plz add persian lp so thanks Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: G630-U10 Build ID: G630-U10V100R001C00B125 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue Jun 17 22:12:57 CST 2014 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Serial: DU2NPX149V030841 ------------------------------------------------------------------------------------------ Activating lang pack... Failed, Languague Pack has been already activated, sometimes you need to do a factory reset after activation. Operation Done. |
12-15-2014, 12:53 | #23 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: WORLDWIDE
Member: 78516 Status: Offline Thanks Meter: 62 | Quote:
How do you root it ? I try all ( vroot, kingo , towelroot ) noe of those had worked ! So can someone give me a clue ? thanks Best regards | |
12-15-2014, 13:18 | #24 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi Only with press click on Read info or Unlock option our module can automatically root your phone in most of the case... you don't need to be worried just try and let me know!!!! |
12-15-2014, 14:58 | #25 (permalink) | |
Member: 1784663 Status: Offline Sonork: 100.1618770 Thanks Meter: 62 | Quote:
must use third party applications for this model i'll talk with mr elcapi on sonorok for this | |
12-15-2014, 15:39 | #26 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,256 | G610 Ok Done Activate All Languajes Quote:
12-15-2014, 15:56 | #27 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Pakistan & UAE (Dubai) Age: 34
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI Y320-U30 Build ID: Y320-U30V100R001C328B500 Hardware ID: MT6572 ------------------------------------------------------------------------------------------ Linux version 3.4.5 (build@build) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Oct 21 20:01:36 CST 2013 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 8628660xxxxxxxxx ------------------------------------------------------------------------------------------ Repairing Imei... New Imei: 862866xxxxxxxxxx;862866xxxxxxxxxx Current Imei(s): -> IMEI_1 : xxxxxxxxxxxx Repairing... Repair Imei Done. Operation Done. |
12-15-2014, 16:41 | #28 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 593061 Status: Offline Thanks Meter: 19 | all ok y330-0151 activate all language pack Code: Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI Y300-0151 Build ID: Y300-0151V100R001C451B184 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0-perf-gf909b34-00176-g2283e75 (android@localhost) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Mon May 27 12:11:52 CST 2013 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 8684420184XXXXX Serial: DU1WSS13CU007811 ------------------------------------------------------------------------------------------ Activating lang pack... Activation has been done. Now, you must perform a factory reset. Restarting Phone... Operation Done. |
The Following User Says Thank You to juan_junior99 For This Useful Post: |
12-15-2014, 17:48 | #29 (permalink) |
Freak Poster Join Date: Mar 2007 Location: www.PH
Member: 477490 Status: Offline Thanks Meter: 74 | Kindly check this link Bro Huawei Y530 unlock done |
12-16-2014, 10:27 | #30 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | y320-u30 failed to activete lang Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI Y320-U30 Build ID: Y320-U30V100R001C298B300 Hardware ID: MT6572 ------------------------------------------------------------------------------------------ Linux version 3.4.5 (build@build) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Jan 2 12:03:54 CST 2014 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 862866028196757 ------------------------------------------------------------------------------------------ Activating lang pack... Failed, Languague Pack has been already activated, sometimes you need to do a factory reset after activation. Operation Done. |
