02-03-2015, 21:02 | #16 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,674 | Before try to repair the imei you need repair the baseband. Best Regards zZ-Team Quote:
02-03-2015, 21:08 | #17 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: California, LA,USA
Member: 1639385 Status: Offline Sonork: 100.1594605 Thanks Meter: 212 | It's a driver problem. Restart your phone , wait until phone completely powers up and try again. It would be okay. best wishes. Quote:
02-03-2015, 22:51 | #21 (permalink) |
Member: 1639385 Status: Offline Sonork: 100.1594605 Thanks Meter: 212 | You must do some preliminary operations in order to repair baseband unknown id, you can check it on the manual, or you can watch users memoirs http://forum.gsmhosting.com/vbb/f717...eport-1910877/ |
02-04-2015, 01:03 | #23 (permalink) |
Member: 1639385 Status: Offline Sonork: 100.1594605 Thanks Meter: 212 | Contact me on sonork. I will help u through the process. Best wishes QUOTE=Viking;10840696]Not solved, drivers reinstaled, but not work[/QUOTE] |
02-04-2015, 02:49 | #24 (permalink) |
Junior Member Join Date: Jul 2006
Member: 311893 Status: Offline Thanks Meter: 9 | Error with u9805 PLEASE see this error i tried with a U9805, and can`t read info, can`t unlock and can`t repair. the imei original is good, the phone on good, and the driver are installed good. |
02-04-2015, 12:33 | #25 (permalink) |
Freak Poster Join Date: Jan 2006 Location: South Africa
Member: 227454 Status: Offline Thanks Meter: 48 | Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI G510-0100 Build ID: G510-0100V100R001C316B174 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0-perf-gb27b50f (android@localhost) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue May 14 12:25:09 IST 2013 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 86803801xxxxx20 Serial: 021XMU9M3A002823 ------------------------------------------------------------------------------------------ Reading Simlock Status... Simlock Status: Phone Unlocked. Operation Done. G510 done after repair imei you have to flash the phone working good. |
02-04-2015, 13:37 | #26 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, please check version of driver, even close all other software that could generate conflict, after that perform the following: * Hisilicon Mode Method This method is based on some special code including ZZ key software. When you type * # * # 2846579 # * # * Project Menu-> background setting-> USB ports setting-> USB ports Setting-> Manufacturer Mode phone automatically switch the port. |
02-04-2015, 13:40 | #27 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi bro please check correct version of driver, disable adb mode and check that not other software could be generating conflict or be open at the same time, after that perform the following: * Hisilicon Mode Method This method is based on some special code including ZZ key software. When you type * # * # 2846579 # * # * Project Menu-> background setting-> USB ports setting-> USB ports Setting-> Manufacturer Mode phone automatically switch the port. |
02-04-2015, 17:32 | #28 (permalink) |
Member: 1639385 Status: Offline Sonork: 100.1594605 Thanks Meter: 212 | Close any soft that could be using the port, I mean, HiSuite or any other daemon or soft. Turn off your phone. Remove sim card and something else. Power On , and repeat procedure again. If ReadFile error appear, please restart phone again wait a minute until phone fully load, activate port and try again. |
