Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 05-07-2019, 16:30   #1 (permalink)
Member: 87188
Thanks Meter: 227
ARE-AL00 honor 8X max, Dead after flah.
I wanted rebrand to global.
Fastboot mode:
SigmaKey 2.30.04 HiSi: Write firmware
(ADB) Writing flash...Ares-L22HWC636CUSTC636D1B134.APP
Firmware: ARS-L22HW 8.2.0.153(C900)
This operation may brick the phone! Are you sure you want to proceed? [YES]
Phone model: ARE-AL00
Version: ARE-AL00 8.2.0.154(C00)
Writing flash rpm...OK
Writing flash pmic...OK
Writing flash tz...OK
Writing flash hyp...OK
Writing flash xbl...OK
Writing flash apdp...OK
Writing flash msadp...OK
Writing flash cmnlib...OK
Writing flash keymaster...OK
Writing flash cmnlib64...OK
Writing flash devcfg...OK
Writing flash lksecapp...OK
Writing flash abl...OK
Writing flash dsp...OK
Writing flash modem...OK
Writing flash bluetooth...OK
Writing flash kernel...OK
Writing flash ramdisk...OK
Writing flash recovery_vendor...OK
Writing flash...Done
Phone dead, only:
Qualcomm HS-USB QDLoader 9008 (com42)
Does anyone know how to revive this?
BR.
Old 05-10-2019, 14:27   #2 (permalink)
Member: 87188
Thanks Meter: 227
I buy bootloader support and download r epair.skf and ARE-AL00-BD 1.0.0.32.skf
SigmaKey v.2.30.04 build 01
183499023 Sigma dongle 2.30, Initializing...OK
Pack 1: Activated
Pack 2: Activated
Pack 3: Activated
--------- 2019-05-10 15:06:12 ---------
SigmaKey 2.30.04b1 Qcom: Write firmware
Sending boot...Failed
Not work.
But not phone problém because nck dongle cqualcomm module wite it in firehause mode:
original Ares-AL00B-BD 1.0.0.40_Board Software, manual select bootloaderimage
and loaderprog_emmc_firehose.mbn
Exe Version: NckBox Qualcomm Module 0.12.5
Operation: Download
Searching for phone.....
Qualcomm HS-USB QDLoader 9008 (COM42) detected.
Hello received.
HW ID: 66001500E1C00C00
PK HASH: A1A5C29846C9881B7A6081EC218212B9B7EB1765EE8843798F 16619D6FCD3FE0
Using custom loader: prog_emmc_firehose.mbn
Arhitecture:64 bits
[64]Sending loader, please wait..
Readed length: 16
Waiting for loader to start...
[1] Send NOP ok, loader start.
Reading partition info, wait.
Volume[0] Size: 17 KB Partitions count: 13
[0]Writing: xbl Start: 65536 length: 5375
[0]Writing: tz Start: 73728 length: 3832
[0]Writing: rpm Start: 81920 length: 440
[0]Writing: hyp Start: 82944 length: 544
[0]Writing: pmic Start: 83968 length: 78
[0]Writing: keymaster Start: 84992 length: 609
[0]Writing: cmnlib Start: 87040 length: 426
[0]Writing: cmnlib64 Start: 89088 length: 520
[0]Writing: dsp Start: 91136 length: 32768
[0]Writing: abl Start: 123904 length: 792
[0]Writing: devcfg Start: 196608 length: 96
[0]Writing: primarygpt Start: 0 length: 34
[0]Writing: backupgpt Start: NUM_DISK_SECTORS-33. length: 33
Erasing FRP, wait.....
Restarting phone.....
Log saved: C:\Documents and Settings\Mester\Dokumentumok\NckBox\qualcomm_modul e\qc_module_Logs\flash_phone__66001500E1C00C00_A1A 5C29846C9881B7A6081EC218212B9B7EB1765EE8843798F166 19D6FCD3FE04.txt
Total Time: 00:00:16
Done.
but it doesn't help.-(
Same, only Qualcomm HS-USB QDLoader 9008
What should I do?
Maybe you need another newer board software?
Old 05-10-2019, 18:50   #3 (permalink)
Member: 266759
You should search 4pda 8x max..it will open thread in Russian. look for official firmware.. From there you can get service firmware for flashing from qfill etc
Old 09-18-2019, 08:39   #4 (permalink)
Member: 1813108
Sonork: 100.1645132
Thanks Meter: 44
its dead in qualcomm mode only
any soluion till now
no loaders working anymore!!
Old 09-18-2019, 11:49   #5 (permalink)
Member: 1813108
Sonork: 100.1645132
Thanks Meter: 44
is your phone ok?
please reply with new update
Old 09-21-2019, 13:58   #6 (permalink)
Member: 2698409
Thanks Meter: 244
Have you found solution? Same situation, cannot accept loaders
Old 09-22-2019, 10:05   #7 (permalink)
Member: 1813108
Sonork: 100.1645132
Thanks Meter: 44
no solution till now
still looking for it
Old 09-22-2019, 10:29   #8 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
Me too.
Model Phone: JSN-AL00a
SW: :JSN-AL00a9.0.1.163(C00E25R1P7)
Android Version: 9
IMEI: :FAILED
Lock state: FBLockState:LOCKED USERLockState:LOCKED
Boot info: locked
After downgrade then phone not alive.
Old 09-29-2019, 01:21   #9 (permalink)
Member: 2390637
i had same issue when i tried to rebrand it but i was able to unbrick,if anyone still have this problem contact me..
Old 09-30-2019, 08:35   #10 (permalink)
Member: 2698409
Thanks Meter: 244
What's the point, if you never reply to my message?
The Following 2 Users Say Thank You to oscar.freire For This Useful Post:
Old 10-09-2019, 00:13   #11 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
is there any solution to this problem
honor8x max dead after update
Old 10-10-2019, 23:50   #12 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
8xmax
problem solved !!
Old 10-11-2019, 02:33   #13 (permalink)
Member: 2698409
Thanks Meter: 244
Originally Posted by recan21 View Post
problem solved !!
Please share the solution
Old 10-29-2019, 08:04   #14 (permalink)
Member: 1813108
Sonork: 100.1645132
Thanks Meter: 44
Are-al10 dead only qualcomm mode
what firmware was inside before its dead?
can send me logs before it was dead?
i can fix it
Old 10-29-2019, 10:22   #15 (permalink)
Member: 2698409
Thanks Meter: 244
i can fix it
Trying to flash boardfirmware, get error at the loader. Loader Sent Failed. You have solution?
Page generated in 0.21764 seconds with 9 queries
