09-11-2018, 16:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | ALCATEL 5049w unlock Direct Unlock for 5049W / 5049Z / REVVL / A30 Fierce Important: in order to perform servicing of these models, you need to download special addon files from Sigma Free section (Alcatel folder) of Boot-Loader.com, and put it into My Documents\SigmaKey\addons\your sigma number folder. 1.Open"MTK" platform from the tab menu in the upper left side of the software 2.Go to "Unlock" tab 3.Turn the phone ON and check your phone's build number: Open menu Settings -> About -> Build Number Turn the phone OFF 4.Select required addon file(in *.skf format) that matches your phone's build number. If there is no match, try the file that matches the specific model 5.Connect turned off phone to PC with USB cable Select ADB interface(fastboot) in the ports selection tab Press "Direct Unlock" button Message "Unlocking phone... Done" indicates that procedure was completed successfully Disconnect the device """""" Select ADB interface(fastboot) in the ports selection tab"""""" here my doubt-this selection not seen in my port selection is my problem-help me set detect as mtk-then goes-so direct unlock not active help me |
09-11-2018, 18:07 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Do exactly as it is shown on this video |
The Following 3 Users Say Thank You to mcandre For This Useful Post: |
01-28-2019, 09:40 | #4 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | Please, read the manual carefully, because unlock method includes some specific features! |
