Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 08-28-2013, 10:41   #1 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Alcatel One Touch 4010x Unlock Problem
I have Alcatel One touch 4010x Unlock Mobile I tryed to calculate unlock code's via Sigmakey After calculate code's I tryed to unlock mobile Code accepted Mobile was Unlocked But if restart the Phone It's again Asking unlock Code .....
I tryed Hardreset And then Again Unlock But Mobile was same problam...Sigma Team i am waiting For ur Replay
Old 08-28-2013, 11:05   #2 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
There are 2 methods to make factory data reset on your phone:
Method 1: Under power on mode
Please go to menu->“Settings” ->“Privacy” ->“Factory data reset;
Method 2: Under power off mode
Turn off the handset, press the volume up key and the Power key at the same time for a few seconds until you see the reset interface, then press “Home” key ->select “wipe data/factory reset” via volume key -> Press “power” key to confirm -> Select “Yes –delete all user data” -> Press “power” key to confirm again -> Please select “reboot system now” and press “power” key to confirm to reboot your phone. The handset can be used without screen unlock pattern after its reboot.
Please note that factory data reset will erase all data from your phone. If you want to quit it before performing factory reset, you can select “reboot system now” or remove the battery and re-insert it, then restart the phone.
ALCATEL ONE TOUCH - Support - Faq
The Following 2 Users Say Thank You to mcandre For This Useful Post:
Old 08-28-2013, 11:09   #3 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Thank's For ur Replay But Allready i Did Hardreset ..After Hardreset Unlocked phone via code's if i reboot Phone It's asking Again code Allso I tryed Engineering mode Enter code ....
Old 08-28-2013, 11:14   #4 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
What provider is this device locked to?
Old 08-29-2013, 10:49   #5 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
NetworkIGI And Country:Malaysia Allso Sigmakey Team can U Share This Modal Windows Sp2 Driver's ? If it's Direct unlock Supported I will try Thank's .
Old 08-29-2013, 11:06   #6 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
@ ChandruChiyyan,
This phone model, OT4010, is not supported for Direct Unlock operation.
At the moment, only Calculate Unlock Codes by IMEI is supported.
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 08-29-2013, 11:24   #7 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
Thanks Meter: 104
Originally Posted by GSM_Support View Post
@ ChandruChiyyan,
Best Regards
GSMServer team
so please give us the solution...
what to do... with code...
thanks
The Following User Says Thank You to harim_1981 For This Useful Post:
Old 12-24-2013, 11:08   #8 (permalink)
Crazy Poster
Member: 830144
Thanks Meter: 7
nice work done but sigma box can do it
Old 02-14-2014, 10:25   #9 (permalink)
Member: 199050
Thanks Meter: 4
Alcatel 4010 Permanent Unlock
@ ChandruChiyyan,
Best Regards
GSMServer team
for permanent unlock of Alcatel 4010, after code calculation by Sigma Key,
dismiss the enter code prompt and dial *#*#3646633#*#* then look for
"SIM LOCK" menu and under each lock category select "PERMANENT UNLOCK" and enter required lock as from the calculations.
Old 03-23-2014, 05:40   #10 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
sir here too same
applied the said procedure many time but again prompt for code at start
help to get rid
thanks to you all by gsmzaman
Old 03-23-2014, 09:51   #11 (permalink)
Member: 2106784
Thanks Meter: 3
es< very naugty phone. i managed to unlock this phone with help this forum.
first calculate code, you can use sigma box
root phone, can use vroot
install Root Uninstaller Pro.
insert sim you want to use, insert code unlock
run Root Uninstaller Pro, Uninstall EM SIM ME LOCK.
hard reset phone
done
Old 03-25-2014, 21:39   #12 (permalink)
Member: 199050
Thanks Meter: 4
Originally Posted by muhammad khalid View Post
sir here too same
help to get rid
sorry didnt get back to you in time but did you solve the problem if not what procedure did you follow after entering that code or send me mail [email protected]
Old 04-12-2014, 14:28   #13 (permalink)
Member: 308730
Thanks Meter: 15
You have to enter code and then turn off the phone and dont take off the battery. Perform Wipe data and wipe cache.
It will never ask again for code.
good luck
The Following User Says Thank You to Pilarense For This Useful Post:
Old 06-23-2014, 14:05   #14 (permalink)
Member: 1728527
Sonork: 100.1668555
Thanks Meter: 67
Perfect
Originally Posted by pilarense View Post
you have to enter code and then turn off the phone and dont take off the battery. Perform wipe data and wipe cache.
Good luck
yeah , its working .....
Phone unlocked permenantly ....thanks...
Old 06-23-2014, 14:09   #15 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
Unlock this phone with Yoda's method and it will stay unlocked even after hard reset.
Page generated in 0.22203 seconds with 8 queries
