08-28-2013, 10:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | Alcatel One Touch 4010x Unlock Problem I tryed Hardreset And then Again Unlock But Mobile was same problam...Sigma Team i am waiting For ur Replay |
08-28-2013, 11:05 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | There are 2 methods to make factory data reset on your phone: Method 1: Under power on mode Please go to menu->“Settings” ->“Privacy” ->“Factory data reset; Method 2: Under power off mode Turn off the handset, press the volume up key and the Power key at the same time for a few seconds until you see the reset interface, then press “Home” key ->select “wipe data/factory reset” via volume key -> Press “power” key to confirm -> Select “Yes –delete all user data” -> Press “power” key to confirm again -> Please select “reboot system now” and press “power” key to confirm to reboot your phone. The handset can be used without screen unlock pattern after its reboot. Please note that factory data reset will erase all data from your phone. If you want to quit it before performing factory reset, you can select “reboot system now” or remove the battery and re-insert it, then restart the phone. ALCATEL ONE TOUCH - Support - Faq |
The Following 2 Users Say Thank You to mcandre For This Useful Post: |
08-28-2013, 11:09 | #3 (permalink) |
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | Thank's For ur Replay But Allready i Did Hardreset ..After Hardreset Unlocked phone via code's if i reboot Phone It's asking Again code Allso I tryed Engineering mode Enter code .... |
08-29-2013, 10:49 | #5 (permalink) |
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | NetworkIGI And Country:Malaysia Allso Sigmakey Team can U Share This Modal Windows Sp2 Driver's ? If it's Direct unlock Supported I will try Thank's . |
08-29-2013, 11:06 | #6 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ ChandruChiyyan, This phone model, OT4010, is not supported for Direct Unlock operation. At the moment, only Calculate Unlock Codes by IMEI is supported. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
08-29-2013, 11:24 | #7 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Quote:
so please give us the solution... what to do... with code... thanks | |
The Following User Says Thank You to harim_1981 For This Useful Post: |
02-14-2014, 10:25 | #9 (permalink) | |
Junior Member Join Date: Nov 2005
Member: 199050 Status: Offline Thanks Meter: 4 | Alcatel 4010 Permanent Unlock Quote:
dismiss the enter code prompt and dial *#*#3646633#*#* then look for "SIM LOCK" menu and under each lock category select "PERMANENT UNLOCK" and enter required lock as from the calculations. | |
03-23-2014, 05:40 | #10 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | Quote:
applied the said procedure many time but again prompt for code at start help to get rid thanks to you all by gsmzaman | |
03-23-2014, 09:51 | #11 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2106784 Status: Offline Thanks Meter: 3 | es< very naugty phone. i managed to unlock this phone with help this forum. first calculate code, you can use sigma box root phone, can use vroot install Root Uninstaller Pro. insert sim you want to use, insert code unlock run Root Uninstaller Pro, Uninstall EM SIM ME LOCK. hard reset phone done |
03-25-2014, 21:39 | #12 (permalink) | |
Member: 199050 Status: Offline Thanks Meter: 4 | Quote:
04-12-2014, 14:28 | #13 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Paraguay
Member: 308730 Status: Offline Thanks Meter: 15 | You have to enter code and then turn off the phone and dont take off the battery. Perform Wipe data and wipe cache. It will never ask again for code. good luck |
The Following User Says Thank You to Pilarense For This Useful Post: |
