Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 02-22-2012, 11:45   #1 (permalink)
Member: 319880
Sonork: 100.1625720
ex108 or cable pinout correct
Hello all
I tried to micro usb cable from Vygis box, gpg, Spiderman, infinity and EX108 just could not communicate with SIGMAKEY.
Could you give me a light
grateful
Old 02-23-2012, 12:49   #2 (permalink)
GSM_Support's Avatar
Member: 121052
@ zoiodopantano,
According to the information that was provided you have tried to connect phone via simple micro-USB cable.
In order to be able to perform unlock or other operation MTK based phone models has to be connected to PC via PC COM port via original COM data cable or using any COM port emulator.
Also, cable pinouts can be found in the "Pinouts and Drivers" section of SigmaKey official web site., please check`em. Cables that were manufactured by our team and was recommended to be used available by this link.
Best Regards
GSMServer team
Old 02-27-2012, 21:31   #3 (permalink)
Member: 319880
Sonork: 100.1625720
@ GsmServeTeam
I believe that this EX108 is still a big mystery to do to communicate with the dongle!
GsmServer the cable is not confirmed for ex 108
Models Supported by USB Cable for Motorola EX-series and Alcatel MTK
Motorola Models Supported by USB Cable for Motorola EX-series and Alcatel MTK
  • EX112
  • EX115
  • EX122
  • EX126
  • EX128
  • EX211
  • EX212
Old 02-28-2012, 07:30   #4 (permalink)
Member: 121052
@ zoiodopantano,
These are MTK-based phone models. In order to be able to detect it and perform unlock/flash operation they suppose to be connected to PC via COM port cable or COM emulator, as it is stated at the official web site. EX-108 as other MTK-based sets can not be unlocked via simple mini/micro USB cable.
Also, at the official web site you can find correct cable pinouts.
Cables that was manufactured by our team working properly with all sets from EX-series.
It was already tested by many users.
Best Regards
GSMServer team
Old 02-28-2012, 18:22   #5 (permalink)
Member: 319880
Sonork: 100.1625720
@ GsmServerTeam
thousand excuses, but not enter my head that I can ex112 and ex108 can not communicate!
follows the log ex112
SigmaKey 1.03.02
///////////////Sigma dongle 1.03, Initializing...OK
Format FFS
USB Serial Port by Vygisoft (COM41), Provider: FTDI, Driver ver.: 2.0.0.0, Date: 18/5/2006
Baud rate: 19200
Release "Power on" button!
Baseband Processor: MT6235, HW Rev. C.00, SW Rev. A.01
Serial number: 27AEBF6C48DAA9F174AF473E04F06FAE
Testing external RAM...64 Mb
Detecting flash...NAND, ID: 00AD00A1-00800015, manufacturer: Hynix
Flash size: 128 Mb, page size: 2048
File system: 78 Mb @ 03200000
Firmware: A8206_LA_PCB01_GPRS_MT6235B_S01.STARLING_G_07_27_0 4R_S
Hardware IMEI: 356466046455419
Formatting FFS might affect calibration data. Press "Yes" if you made calibration backup. [YES]
Done
Old 03-11-2012, 01:16   #6 (permalink)
Member: 319880
Sonork: 100.1625720
A great surprise to everyone ...
Solution for 108 ex so open and soldering wire
SigmaKey 1.05.00
xxxxxxx2 Sigma dongle 1.04, Inicializacao...OK
Restabelecimento de IMEI
USB Serial Port (COM5), Suministrador: FTDI, Versao de driver: 1.0.2154.0, Data: 15/4/2004
Velocidade de cambio: 19200
Resposta inesperavel do telefone
Solte o botao "Ligacao"!
Procesador Baseband: MT6235, HW Rev. C.00, SW Rev. A.01
Numero de serie: 6681A43FAB83A3822088C4E35D859A87
Cheque da memoria RAM externa do telefone...64 Mb
Identificacao da memoria flash...NAND, ID: 00AD00A1-00000015, fabricante: Hynix
Tamanho da memoria flash: 128 Mb, tamanho da pagina: 2048
Sistema de arquivos: 78 Mb @ 03200000
Firmware: A8223_LATAM_PCB01_GPRS_MT6235B_S01.ERIN_G_07_18_00 RP_S
Hardware IMEI: 356456042164503
Restabelecimento de IMEI: 3536980452022xx
Executado
credits a Luis Fernando
SP- BRASIL
The Following 2 Users Say Thank You to zoiodopantano For This Useful Post:
Old 03-12-2012, 13:31   #7 (permalink)
Member: 319880
Sonork: 100.1625720
pinout correct
Old 03-22-2012, 23:48   #8 (permalink)
Member: 92317
Originally Posted by zoiodopantano View Post
pinout correct
this pinout not work for me any news about this
Old 03-23-2012, 03:55   #9 (permalink)
Member: 319880
Sonork: 100.1625720
@ cdmagsm03
10 ex108 successfully
very easyyyyyyyyyyy ......
Old 05-28-2012, 16:56   #10 (permalink)
Member: 76937
EX109 sucessfully too
Old 05-29-2012, 23:25   #11 (permalink)
cbcelular's Avatar
Member: 217679
Exclamation
Another solution without opening the unit and solder wire is to use Chinese Box to find the pinouts for example GPGDragon and others to use them as an interface, just simply use the PCB (connector model 04A) P2 connector (headset) with 3-way and directly connect the device and to read the pinouts and woe can use to repair and peaceful SigmaKey flasher, I have done tests and it works well.
Old 06-23-2012, 01:52   #12 (permalink)
daroas's Avatar
Member: 194078
i have this error using GPG:
Baud rate: 19200
Serial number: 216131688D46BBC900000000AC468BD1
Sending boot...Missing response from phone
Old 06-23-2012, 10:08   #13 (permalink)
mcandre's Avatar
Member: 239548
Pinout:
Other pinouts are here
daroas, read the manual once again.
Press and hold "Power ON" button on the phone
As soon as SigmaKey shows an appropriate message in the log window, release "Power ON" button
It means that you have to press and hold the button for several seconds.
Old 06-25-2012, 20:52   #14 (permalink)
daroas's Avatar
Member: 194078
After i make one cable work fine
Old 06-26-2012, 18:09   #15 (permalink)
daroas's Avatar
Member: 194078
Another help for all.Everyone saw a little higher than I was with the error below on a EX108
Baud rate: 19200
Even after making an RJ45 cable with phone P2 I had the error in a model and only had success after formatting the device.
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! andrew bennett Main Sales Section 1 07-27-1999 21:31
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 0.42832 seconds with 12 queries
