11-14-2017, 17:29 | #1 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | FACTORY MODE: Repair bricked Huawei device using board software Use this guide only for cases, when phone is software bricked and doesn’t show any devices while connected to PC, or shows HUAWEI USB COM 1.0 device (VID12D1 PID3609). • Factory flash files: boot-loader.com -> downloads -> Sigma -> Huawei -> Factory Flash files. • Drivers for device HUAWEI USB COM 1.0 (in the "FACTORY MODE" manual) STEP 0 Device has to be set to FACTORY mode. It should be detected as HUAWEI USB COM 1.0 in the System. In some cases Testpoint has to be used to force the device to FACTORY mode. STEP 1 Repair the device using Board Software file (*.skf format) taken from boot-loader flash file area. Code: SigmaKey 2.26.13 HiSi: Write firmware HUAWEI USB COM 1.0 (COM225), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10.08.2014, USB\VID_12D1&PID_3609&REV_0000 Repairing...HL3ALICEMAA001077.skf Writing flash...ptable...OK Writing flash...fastboot1...OK Writing flash...fastboot...OK Writing flash...boot...OK Writing flash...recovery...OK Writing flash...mcuimage...OK Writing flash...modemimage...OK Writing flash...dsp...OK Writing flash...dtimage...OK Writing flash...hifi...OK Writing flash...modemnvm1...OK Formatting FFS...oeminfo...OK Writing flash...oeminfo...OK Formatting FFS...cust...OK Formatting FFS...misc...OK Writing flash...cache...OK Writing flash...system...OK Writing flash...system...OK Writing flash...system...OK Writing flash...userdata...OK Writing flash...trustfirmware...OK Writing flash...teeos...OK Writing flash...securetystorage...OK Writing flash...Done Reflash the phone using original update.app file in FASTBOOT mode (vol- and insert USB cable) Code: SigmaKey 2.26.13 HiSi: Write firmware (ADB) Writing flash...UPDATE.APP Firmware: ALE-L21C432B524 Phone model: :HUAWEI Version: :HL3ALICEMAA001077 Writing flash modemimage...OK Writing flash modemnvm1.0...OK Writing flash mcuimage...OK Writing flash hifi...OK Writing flash dsp...OK Writing flash dtimage...OK Writing flash teeos...OK Writing flash trustfirmware...OK Writing flash securetystorage.0...OK Writing flash nvme...OK Writing flash fastboot...OK Writing flash recovery...OK Writing flash recovery2...OK Writing flash boot...OK Writing flash system.0...OK Writing flash system.1...OK Writing flash system.2...OK Writing flash system.3...OK Writing flash system.4...OK Writing flash system.5...OK Writing flash cache.0...OK Writing flash cust.0...OK Writing flash userdata.0...OK Writing flash...Done Restarting phone...OK a) Repair IMEI and other numbers (via Manufacture mode) Code: SigmaKey 2.26.13 HiSi: Repair IMEI Connecting.... Android Adapter PCUI (COM263), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 28.12.2015, USB\VID_12D1&PID_105C&REV_9999&MI_02 Testing external RAM...2 Gb Detecting flash...eMMC, Flash size: 16 Gb Firmware: ALE-L21 C900B560, Date: Tue Apr 19 04:35:52 CST 2016 Boot Version: DailyBuild_201604190429_BOOT, FastBoot Version: DailyBuild_201604190429_FASTBOOT Recovery Version: (unknow), System Version: C900B560_SYSTEM Getting info.... Removing firmware protection...Skipped Software IMEI: 000000000000000 Repaired IMEI: 352431546546541 Done Please perform Factory data reset via phone's menu. Code: SigmaKey 2.26.13 HiSi: Save settings Connecting.... Android Adapter PCUI (COM263), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 28.12.2015, USB\VID_12D1&PID_105C&REV_9999&MI_02 Testing external RAM...2 Gb Detecting flash...eMMC, Flash size: 16 Gb Firmware: ALE-L21 C900B560, Date: Tue Apr 19 04:35:52 CST 2016 Boot Version: DailyBuild_201604190429_BOOT, FastBoot Version: DailyBuild_201604190429_FASTBOOT Recovery Version: (unknow), System Version: C900B560_SYSTEM Getting info.... Removing firmware protection...Skipped Removing firmware protection....Done Provider: hw/default Writing data...Done Please reflash the original firmware. STEP 4 Reflash the phone now in UPGRADEMODE using original update.app file (vol+vol- and insert USB cable) Code: SigmaKey 2.26.13 HiSi: Write firmware DBAdapter Reserved Interface (COM264), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 28.12.2015, USB\VID_12D1&PID_105C&REV_9999&MI_04 Writing flash...UPDATE.APP Firmware: ALE-L21C432B524 Hardware IMEI: 020304050607080 Writing flash SHA256RSA OK Writing flash CRC OK Writing flash CURVER OK Writing flash VERLIST OK Writing flash EFI OK Writing flash MODEMIMAGE OK Writing flash MODEMNVM1 OK Writing flash MCUIMAGE OK Writing flash HIFI OK Writing flash DSP OK Writing flash DTIMAGE OK Writing flash TEEOS OK Writing flash TRUSTFIRMWARE OK Writing flash SECURETYSTORAGE OK Writing flash NVME OK Writing flash FASTBOOT1 OK Writing flash FASTBOOT OK Writing flash RECOVERY OK Writing flash RECOVERY2 OK Writing flash BOOT OK Writing flash SYSTEM OK Writing flash CACHE OK Writing flash CUST OK Writing flash USERDATA OK Done Best Regards GSMServer team |
The Following 10 Users Say Thank You to GSM_Support For This Useful Post: |
11-14-2017, 23:43 | #2 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Ostrów Wielkopolski Age: 39
Member: 87958 Status: Offline Thanks Meter: 15 | Code: --------- 2017-11-14 23:40:27 --------- SigmaKey 2.26.13 HiSi: Write firmware HUAWEI USB COM 1.0 (COM63), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 2014-08-10, USB\VID_12D1&PID_3609&REV_0000 Repairing...HL3ALICEMAA001077.skf Connect this phone in FastBoot mode and retry operation! two options - that p8 lite is hard bricked / hardware, or your solution is not working correctly ? ================edit: magically, after manual reboot vol- + power = i've got fastboot mode!!! flashing now with update.app........... |
The Following User Says Thank You to condi1987 For This Useful Post: |
01-06-2018, 16:54 | #5 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Lahore
Member: 1611524 Status: Offline Sonork: 100.1637126 Thanks Meter: 385 | after all these steps all is ok but no service or emergency call only. so mobile network options hidden or disable. anyone hav solution? |
01-07-2018, 11:29 | #6 (permalink) | ||
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | Quote:
the cell phone but when I flash with the original rom, the cell phone leaves the image like an old TV. TP works perfect, for those who do not connect them as Huawei USB COM 1.0, although fastboot also flashes, excellent with the repair file log flash with repair file Quote:
The Following User Says Thank You to cellcarcol For This Useful Post: |
01-09-2018, 10:59 | #8 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
Try using another firmware. It is possible that your phone's hardware doesn't support this type of flash file | |
The Following User Says Thank You to mcandre For This Useful Post: |
01-10-2018, 13:08 | #9 (permalink) | |
Member: 138781 Status: Offline Thanks Meter: 850 | imei this ok bt this ok imei this ok Quote:
yes, use many I was able to flash only the system. the cell phone turns on well, but does not pick up a signal. if I flash with the normal flash it looks like a clock | |
01-10-2018, 14:28 | #10 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ cellcarcol, In order to fully restore phone you need to flash it with full phone firmware, not only System partition. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
01-11-2018, 01:49 | #11 (permalink) | |
if I use the complete firmware, it looks like a clock (an image I posted earlier) and then it does not happen, it does not do anything | |
01-11-2018, 14:32 | #12 (permalink) | |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ cellcarcol, More likely that the oem zone was flashed. To restore phone's network it is required to flash oem zone from the phone that detects network properly. After that perform IMEI Repair operation and Direct Unlock As it is stated in the manual: Quote:
GSMServer team | |
01-23-2018, 21:13 | #13 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2795198 Status: Offline Thanks Meter: 22 | Phone stays in bootloop and don't enter fastboot mode. It gets error no 14 and opens error mode and restarts endlessly. None of key combinations work. How to flash it? Its hardbricked already. |
01-24-2018, 10:11 | #15 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | |
