Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 06-04-2012, 10:23   #1 (permalink)
Member: 328688
Thanks Meter: 981
G five g6600 stuck on touch celebration
HERE LOG IT STUCK ON TOUCH CELEBRATION I READ BACK UP HERE FLASH
355887040007107_HEXING53_09A_GEMINI_PCB01_GPRS_MT6 253_S00_B059_2_L45_V102.rar
Prolific USB-to-Serial Comm Port (COM5), Provider: Prolific, Driver ver.: 2.0.13.130, Date: 19/11/2009
Baud rate: 19200
Release "Power on" button!
Baseband Processor: MT6253, HW Rev. A.02, SW Rev. A.00
Serial number: CE700A8F9C9DCF89425480E921632E84
Testing external RAM...8 Mb
Detecting flash...NOR, ID: 00898903-00000000, manufacturer: Intel
Flash size: 16 Mb, BOTTOM
File system: 2 Mb @ 00E00000
Firmware: HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.B059_2_L45_V102
Hardware IMEI: Not found
Software IMEI 1: 3558XXXXXXXXXXX
Software IMEI 2: 355XXXXXXXXXXX
Formatting FFS will destroy IMEI. Are you sure you want to proceed? [YES]
Done
Baud rate: 19200
Software IMEI 1: 355887XXXXXXXXX
Software IMEI 2: 35588XXXXXXXXXX
Mounting system disk...#1
Repaired IMEI 1: 355XXXXXXXXXX
Repaired IMEI 2: 355XXXXXXXXXX
Done
Old 06-04-2012, 11:54   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 64,240
@ arshad sunny,
Provide us with more detailed information, please.
In what state have you received this set?
Did Format FFS procedure helped?
What is current phone state?
Best Regards
GSMServer team
Old 06-04-2012, 12:12   #3 (permalink)
Member: 328688
Thanks Meter: 981
Originally Posted by GSM_Support View Post
@ arshad sunny,
Best Regards
GSMServer team
phone come with user lock code i just format it it go dead i read back up write firmware still dead then i write backup it alive again now bt stuck on touch celebration almost 10 mint i touch nothing happen
Old 06-04-2012, 13:26   #4 (permalink)
Member: 121052
Sonork: 100.107126
@ arshad sunny,
Backup copy you have uploaded will be deeply analyzed.
Best Regards
GSMServer team
Old 06-04-2012, 13:35   #5 (permalink)
Member: 328688
Thanks Meter: 981
@ arshad sunny,
Best Regards
GSMServer team
ok i will wait for good news
Old 06-05-2012, 10:24   #6 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,188
Do you know that you are able to Read user Code with Sigma?
If you had read the user code (without format ffs) you would have saved users information (phonebook, sms etc).
Check "Read User Code Manual"
Old 06-05-2012, 19:47   #7 (permalink)
Member: 328688
Thanks Meter: 981
still waiting,....,....,,...
Old 06-06-2012, 12:14   #8 (permalink)
Member: 121052
Sonork: 100.107126
@ arshad sunny,
Have you read this backup copy before performing Format FFS operation or after it was done?
Please specify step-by-step operations you have performed.
Best Regards
GSMServer team
Old 06-06-2012, 13:00   #9 (permalink)
Member: 328688
Thanks Meter: 981
@ arshad sunny,
Best Regards
GSMServer team
I READ AFTER I DONE format ffs
Old 06-06-2012, 14:35   #10 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,188
You didn't specify clearly all actions (step-by-step) you have done to the phone.
According to your post:
1. i just format it it go dead - In what state was the phone after format ffs?
2. i read back up - from "dead phone"?
3. write firmware still dead
4. then i write backup it alive again - phone "revived" after flashing with backup from dead phone?
5. now bt stuck on touch celebration almost 10 mint i touch nothing happen - In my opinion something is definitely wrong with phone's hardware
Old 06-06-2012, 15:33   #11 (permalink)
Member: 328688
Thanks Meter: 981
lol there nothing wrong with hardware ok i m working on china fone long time ok maybe it didn't go dead after i format it 1st i did read code direct unlock
if i hve same phone like this i will fix it up
bt i dnt hve if any one hve just backup flash upload here
leave all this Q ok get me flash file of this fone
Old 06-06-2012, 15:36   #12 (permalink)
Member: 121052
Sonork: 100.107126
@ arshad sunny,
To be able to help we need to know step by step operation you've performed and phone state after each operation. It will help us to determine what can go wrong with it.
Provide us with more detailed information on this case, please.
Best Regards
GSMServer team
Old 06-06-2012, 15:54   #13 (permalink)
Member: 328688
Thanks Meter: 981
here all wht i hve
Software IMEI 1: 3586xxxxxxxxxxxx
Software IMEI 2: 35xxxxxxxxxxxxxxxx
Writing flash 3% (295 Kb/sec) Missing response from phone
Operation log saved to "C:\Documents and Settings\CH ARSHAD\Desktop\SigmaKey log 29-02-2012 back up.txt"
SigmaKey 1.08.06 MTK: Write backup
Baud rate: 19200
Unexpected response from the phone
Baud rate: 19200
File transferring...Data checksum error
Baud rate: autodetect
Cancelled
Baud rate: 19200
Baud rate: 19200
SigmaKey 1.08.06 MTK: Write firmware
Baud rate: 19200
Software IMEI: Not found
Writing flash...Done
Baud rate: 19200
Software IMEI 1: 358xxxxxxxxxxxxxxxxx
Software IMEI 2: 35xxxxxxxxxxxxxxxxxx
Writing flash 89% (267 Kb/sec) Missing response from phone
Baud rate: 19200
Serial number: 00000000000000000000000000000000
Sending boot...Unexpected response from the phone
Baud rate: 19200
Software IMEI 2: 358xxxxxxxxxxx
SigmaKey 1.08.06 MTK: Repair IMEI
Baud rate: 19200
Baud rate: 19200
Software IMEI 1: 35588xxxxxxxxxxxxxxxxxx
Software IMEI 2: 35588xxxxxxxxxxxxxxx
Repaired IMEI 1: 35588xxxxxxxxxxxx
Repaired IMEI 2: 355887cxxxxxxxxxxx
Done
Old 06-07-2012, 08:21   #14 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,188
If you're working with Chinese phones long time, you really need to understand that you must save backup before any action (flash, format ffs etc). It is also specified at official web site of SigmaKey.
Old 06-07-2012, 08:29   #15 (permalink)
Member: 328688
Thanks Meter: 981
u really hve nothing do except chk post where wrong this 1st time i ever had problem like this i naver any problem if i format phone here
y u dnt get me flash file ok if u dnt get me flash file then dnt reply me
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.40556 seconds with 8 queries
