09-08-2018, 10:41 | #1 (permalink) |
Insane Poster Join Date: Jan 2015 Location: on the moon
Member: 2328492 Status: Offline Thanks Meter: 12 | help repair imei alcatel 5045x 963851048 Sigma dongle 2.29, Initializing...OK Pack 1: Activated Pack 2: Activated Pack 3: Activated --------- 2018-09-08 11:16:52 --------- SigmaKey 2.29.01b2 ADB: Ripara IMEI * daemon not running. starting it now * * daemon started successfully * ^ Dispositivo ADB Versione: Linux version 3.18.19 (int@int-103) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Sat Jul 2 12:47:48 CST 2016 Processore Baseband: MT6735M Leggendo hardware IMEI....Errore avvio driver |
09-08-2018, 12:09 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ maxdanapoli, Perform following operations:
Best Regards GSMServer team |
09-08-2018, 12:13 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | 1.Install custom TWRP recovery for your phone 2.Enter recovery mode. The Recovery screen should appear. 3.Connect the phone to PC using USB cable 4.Select "Android ADB" platform from the tab menu in the upper left side of the software. 5.Go to "IMEI" tab. 6.Select "Adb interface" in the ports selection tab. 7.Enter IMEI number in the "Phone IMEI" field. 8.Press "Repair IMEI" button. 9.The message "Done" indicates that procedure has been completed successfully. 10.Wait till the phone reboots. How to install recovery http://forum.gsmhosting.com/vbb/f719.../#post12838449 1.Enable Developer options (as usual) 2.Developer options -> USB debugging (Debug mode when USB is connected) -> ON! 3.Developer options -> OEM unlocking (Allow the bootloader to be unlocked) -> ON! 4.adb reboot bootloader 5.fastboot -i 0x1bbb oem unlock 6.fastboot flash recovery recovery.img |
