Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 11-26-2012, 15:32   #1 (permalink)
blinet's Avatar
Member: 17405
Thanks Meter: 257
how to unlock huawei u9200 ?
tnx
Old 11-26-2012, 16:02   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 71,429
@ blinet,
Please refer to this link for the detailed, step-by-step, unlock manual of Huawei U9200 phone model.
Please notice that this handset, as other Huawei Android sets, suppose to be connected to PC in a Fastboot mode in order to be unlocked. Detailed manuals on how to enter phone in Fastboot mode available here.
P.S. in case if you're dealing with any difficulties to unlock phone, please post here full log file along with the detailed problem description.
Best Regards
GSMServer team
Old 11-26-2012, 16:11   #3 (permalink)
blinet's Avatar
Member: 17405
Thanks Meter: 257
i'm in fastboot mode, but sigma can't see DBAdapter Reserved Interface or other android driver, have you proper u9200 fastboot mode driver?
The Following User Says Thank You to blinet For This Useful Post:
Old 11-27-2012, 07:23   #4 (permalink)
Member: 121052
Sonork: 100.107126
@ blinet,
Huawei Android Drivers available at the official web site in the Downloads->Drivers section.
Did you try to install them?
If you're dealing with any difficulties, please make a screenshot and post it here.
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 11-27-2012, 07:42   #5 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,480
How do you set your phone to the fastboot mode?
  • Switch the device OFF
  • Remove the battery and hold it removed for 10 seconds, then place it back
  • Press and hold down Vol - and Power buttons simultaneously till your phone completely freezes
Here is the driver
Phone will be detected as Android Sooner Single ADB Interface in the device manager.
Also here is the video example on how to enter fastboot mode and to unlock the phone.
The Following User Says Thank You to mcandre For This Useful Post:
Old 11-27-2012, 10:03   #6 (permalink)
blinet's Avatar
Member: 17405
Thanks Meter: 257
ok, driver finally installed on win7 64bit, but i have problem with unlocking
SigmaKey 1.18.01
936122276 Sigma dongle 1.20, Initializing...OK
SigmaKey 1.18.01 Qcom: Direct unlock
Android Sooner Single ADB Interface, Version 0.5, Name: Blaze, Serial number: 690A000200000001
Unsupported phone model
Old 11-27-2012, 10:52   #7 (permalink)
Member: 121052
Sonork: 100.107126
@ blinet,
Your case were transferred to the developers team and getting deeply analyzed.
Best Regards
GSMServer team
The Following 2 Users Say Thank You to GSM_Support For This Useful Post:
Old 04-27-2014, 23:59   #8 (permalink)
Member: 168650
Thanks Meter: 5
error HUAWEI_U9200_HuaweiU9200
Originally Posted by GSM_Support View Post
@ blinet,
Best Regards
GSMServer team
SigmaKey 1.40.00 Qcom: Liberación directa
* daemon not running. starting it now *
* daemon started successfully *
^ Android Adapter ADB Interface
Versi?n: Linux version 3.0.8-00018-g3e8bc35 ([email protected]) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #1 SMP PREEMPT Mon Jan 28 20:03:32 CST 2013
Modelo del teléfono: HUAWEI U9200
Firmware: HuaweiU9200
Fecha: Mon Jan 28 19:44:22 CST 2013
Por favor, envíe el archivo
C:\Users\Eudo Maldonado\Documents\SigmaKey\temporary backup\HUAWEI_U9200_HuaweiU9200_Mon Jan 28 194422 CST 2013 (1).skb
a [email protected]
Archivo incorrecto
HUAWEI_U9200_HuaweiU9200_Mon Jan 28 194422 CST 2013 (0) - Download - 4shared
Old 04-28-2014, 07:11   #9 (permalink)
Member: 121052
Sonork: 100.107126
@ wrecker01,
U9200 is already supported for unlock operation in latest software version.
Best Regards
GSMServer team
Old 02-02-2015, 18:44   #10 (permalink)
Member: 709917
Thanks Meter: 6
Whats is problem??
SigmaKey v.2.08.01
905091739 Sigma dongle 2.08, Initializing...OK
Pack 1: Not activated
--------- 2015-02-02 19:38:21 ---------
SigmaKey 2.08.01 Qcom: Direct unlock
^ ROMaster ADB Interface, Version 0.5, Name: Blaze, Serial number: 67B4000200000001
Old 02-03-2015, 07:42   #11 (permalink)
Member: 121052
Sonork: 100.107126
@ SkyNp,
According to the provided information Direct Unlock operation is getting performed improper.
First of all Pack1 activation is required in order to be able to service U9200 phone model.
Also, please double check Direct unlock manual for this handset, it is required to select ADB platform for servicing of this phone.
Best Regards
GSMServer team
Old 10-20-2015, 16:10   #12 (permalink)
Member: 2334138
Thanks Meter: 71
Huawei Ascend P1 U9200 unlock done Sigmakey
Root with Sigma software.
Download addon Addons - Sigma - MTK, Qualcomm, Broadcom, TI OMAP based flashing, unlocking, repair IMEI solution and extract it into Sigma addon folder (C:\Users\Alexandar\Documents\SigmaKey\addons)
Direct unlock using adb platform.
SigmaKey 2.13.00 ADB: Direct unlock
^ Android Composite ADB Interface
Version: Linux version 3.0.8 ([email protected]) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #1 SMP PREEMPT Wed Jul 4 00:36:27 CST 2012
Phone model: HUAWEI U9200
Android 4.0.3; Firmware: HuaweiU9200; Date: Tue Jul 3 23:33:52 CST 2012
Version: U9200-1V100R001C185B104
Baseband Firmware: IMC1202_20120531_PENTA
Baseband Processor: OMAP4460
Software IMEI: 863102011648xxx
Unlocking phone...Done
Restarting phone...Done
The Following User Says Thank You to ru.mobile For This Useful Post:
Old 12-25-2015, 08:35   #13 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,480
  • Enable "USB Debugging" on your Android device
  • Set the phone into the Manufacture Mode by entering *#*#2846579#*#* code (follow the instruction from the Enable Manufacture Mode manual)
  • Install phone drivers (only if the phone is connected for the first time).
  • select "Comneon Mobile High-speed Modem"
SigmaKey 2.14.03b1 HiSi: Direct unlock
Baseband Processor: Infineon X-GOLD626, Engineering sample 2.2
Firmware: IMC1202_PENTA
Version: XMM6260_V2_SMPH_LARGEBLOCK_NAND_REV_2.10 2013-Aug-26 14:57:43 PDB_NOT_AVAILABLE
Software IMEI: 8631011111
Security area saved to "C:\Documents and Settings\111\My Documents\SigmaKey\security backup\86310111 IMC1202_PENTA XMM6260_V2_SMPH_LARGEBLOCK_NAND_REV_2_10 2013-Aug-26 145743 PDB_NOT_AVAILABLE.skb"
Old 09-01-2016, 22:54   #14 (permalink)
ASIEDU ANNOR's Avatar
Member: 510345
Thanks Meter: 34
hello I've Huawei u9200 with a null imei.
The manufacturer codes do not work. I need help.
Thanks
Old 09-02-2016, 08:07   #15 (permalink)
Member: 121052
Sonork: 100.107126
@ ASIEDU ANNOR,
Try to re-flash phone and repeat Repair IMEI operation according to this manual.
After that post results in a current thread.
Best Regards
GSMServer team
Page generated in 0.45219 seconds with 8 queries
