08-30-2018, 10:04 | #31 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Remove FRP for the NEWEST Huawei HiSilicon and Qualcomm smartphones Do everything according to the manual |
08-30-2018, 10:42 | #32 (permalink) | |
Freak Poster Join Date: Jul 2014 Location: pakistan Age: 35
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | i get another eml l29 p20 not showing allow rsa option....i reinstalled the driver but rsa allow dont comup on screen... Quote: | |
08-30-2018, 10:53 | #33 (permalink) |
No Life Poster Join Date: Jan 2005 Location: abidmobile Age: 48
Member: 102445 Status: Offline Sonork: 100.1603645 Thanks Meter: 77 | hello sir The phone will ask to confirm RSA key fingerprint. If phone is not asking for RSA key fingerprint: Cancel the Remove FRP operation. Reboot the phone manually. reboot many time but not ask for rsa fingerprint. more suggestion plz |
08-30-2018, 11:12 | #34 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | king2050, what drivers do you use? Use drivers from Sigma manual - Remove FRP for the NEWEST Huawei HiSilicon and Qualcomm smartphones |
The Following User Says Thank You to mcandre For This Useful Post: |
08-30-2018, 11:13 | #35 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | abidfarooq, what drivers do you use? Use drivers from Sigma manual - Remove FRP for the NEWEST Huawei HiSilicon and Qualcomm smartphones |
08-30-2018, 11:20 | #36 (permalink) |
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | I used from sigma site.. Sent from my iPhone using Tapatalk |
08-30-2018, 11:36 | #37 (permalink) | |
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | Quote:
HEY i used the same driver but still not showing allow button i reset the phone also...but still same using window 10.. | |
08-30-2018, 11:36 | #38 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | If phone is not asking for RSA key fingerprint:
08-30-2018, 11:37 | #39 (permalink) |
08-30-2018, 11:37 | #40 (permalink) |
08-30-2018, 11:48 | #41 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 126 | To install the drivers for required phone follow this https://gsmserver.com/nfs/content/61...te10_driver.7z Select "Android ADB" platform from the tab menu in the upper left side of the software. Go to "HiSilicon" tab, if you have HiSilicon-based phone. Or go to Qualcomm tab, if your phone is Qualcomm-based. Turn the phone ON and connect it to PC with the USB cable. Select “Android ADB interface” port. Press “Remove FRP” button. The phone will ask to confirm RSA key fingerprint. If phone is not asking for RSA key fingerprint: Cancel the Remove FRP operation. Reboot the phone manually. Run the Remove FRP operation once again. The message "Removing FRP… Done" indicates that procedure has been completed successfully. Disconnect the phone. Reboot the phone. Perform Master Reset from the phone menu. |
08-30-2018, 11:50 | #43 (permalink) | |
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 126 | Quote:
Select "Android ADB" platform from the tab menu in the upper left side of the software. Go to "HiSilicon" tab, if you have HiSilicon-based phone. Or go to Qualcomm tab, if your phone is Qualcomm-based. Turn the phone ON and connect it to PC with the USB cable. Select “Android ADB interface” port. Press “Remove FRP” button. The phone will ask to confirm RSA key fingerprint. If phone is not asking for RSA key fingerprint: Cancel the Remove FRP operation. Reboot the phone manually. Run the Remove FRP operation once again. The message "Removing FRP… Done" indicates that procedure has been completed successfully. Disconnect the phone. Reboot the phone. Perform Master Reset from the phone menu. | |
08-30-2018, 13:42 | #45 (permalink) |
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | on same phone adb option comesup on some phone allow option dont com up....easy to reset frp with hand...with box u have to fight...i open 3 phone with box but 2 phone was not showing allow option...i used the hand method... |
