Huawei ine-lx1 xml file for remove frp Hi all I need xml file for remove frp with sigma box any one have this file Thanks |
FRP remove for this phone available via fastboot mode (new security is not supported). |
Select "HISILICON" platform from the tab menu in the upper left side of the software Go to "Service" bookmark Select from drop-down list the required platform that fits to your device HiSilicon [ Kirin XXX ][v]. If you do not select the platform, the software will ask you to select *.xml file from the factory software that fits this phone (in the manufacturer's original format). Connect the phone to PC using USB cable in the FACTORY mode It should be detected as HUAWEI USB COM 1.0 device (VID12D1 PID3609) in the System. In most cases Testpoint has to be used to force the device to FACTORY mode Select "HUAWEI USB COM 1.0 device" in the ports selection tab. Press "Remove FRP" button The message "Removing FRP… Done" indicates that procedure has been completed successfully Disconnect the handset from PC This is the procedure for remove fro with to in my case I need xml file |
result will be same my case is here http://forum.gsmhosting.com/vbb/f719.../#post13732444 and frp do not gone standart process https://yadi.sk/d/uZn8yW9Z4QH0RQ |
this file ANE-BD_1.0.0.39_Download.xml can work with INE-LX1 or not |
when i try with it i have this error SigmaKey 2.33.02 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM402), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100 Inconsistent file "File I/O operation failed: C:\Users\slaoui\Desktop\bootloaderimage\sec_xloade r.img" |
here is correct:https://yadi.sk/d/CUFcjnaPpjaojA |
same error sir thanks for your reply |
where to download xml hy can you please tell me where to download xml for models who are not in the default list like ine lx1 thanx |
no need xml file bro just reed this text... Go to "Service" bookmark Select from drop-down list the required platform that fits to your device HiSilicon [ Kirin XXX ][v]. If you do not select the platform, the software will ask you to select *.xml file from the factory software that fits this phone (in the manufacturer's original format). |
Kirin 710 added. |
