07-12-2019, 09:40 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | FRP remove for this phone available via fastboot mode (new security is not supported). |
The Following User Says Thank You to mcandre For This Useful Post: |
07-12-2019, 11:25 | #4 (permalink) |
Freak Poster Join Date: Jun 2005 Location: RABAT Age: 49
Member: 153848 Status: Offline Thanks Meter: 25 | Select "HISILICON" platform from the tab menu in the upper left side of the software Go to "Service" bookmark Select from drop-down list the required platform that fits to your device HiSilicon [ Kirin XXX ][v]. If you do not select the platform, the software will ask you to select *.xml file from the factory software that fits this phone (in the manufacturer's original format). Connect the phone to PC using USB cable in the FACTORY mode It should be detected as HUAWEI USB COM 1.0 device (VID12D1 PID3609) in the System. In most cases Testpoint has to be used to force the device to FACTORY mode Select "HUAWEI USB COM 1.0 device" in the ports selection tab. Press "Remove FRP" button The message "Removing FRP… Done" indicates that procedure has been completed successfully Disconnect the handset from PC This is the procedure for remove fro with to in my case I need xml file |
07-12-2019, 11:37 | #5 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Quote:
result will be same my case is here http://forum.gsmhosting.com/vbb/f719.../#post13732444 and frp do not gone standart process https://yadi.sk/d/uZn8yW9Z4QH0RQ Last edited by vasko_bojilov; 07-12-2019 at 11:44. | |
07-12-2019, 22:42 | #7 (permalink) |
Member: 153848 Status: Offline Thanks Meter: 25 | when i try with it i have this error SigmaKey 2.33.02 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM402), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100 Inconsistent file "File I/O operation failed: C:\Users\slaoui\Desktop\bootloaderimage\sec_xloade r.img" |
07-13-2019, 10:37 | #8 (permalink) | |
here is correct:https://yadi.sk/d/CUFcjnaPpjaojA | |
The Following User Says Thank You to vasko_bojilov For This Useful Post: |
08-08-2019, 16:38 | #11 (permalink) | |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Quote:
no need xml file bro just reed this text... Go to "Service" bookmark Select from drop-down list the required platform that fits to your device HiSilicon [ Kirin XXX ][v]. If you do not select the platform, the software will ask you to select *.xml file from the factory software that fits this phone (in the manufacturer's original format). | |
The Following User Says Thank You to pintu_das For This Useful Post: |
01-29-2020, 09:25 | #12 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: POland
Member: 60746 Status: Offline Thanks Meter: 56 | Quote:
06-25-2020, 12:14 | #13 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | Quote:
Kirin 710 added. | |
The Following User Says Thank You to Gsmserver For This Useful Post: |
