09-09-2019, 14:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: BANGLADESH DHAKA Age: 37
Member: 795131 Status: Offline Sonork: 100.1678118 Thanks Meter: 92 | HUAWEI P20 lite HWV32 UNLOCK SUCCESS Set the phone into the Manufacture Mode by entering *#*#2846579#*#* code (follow the instruction from the Enable Manufacture Mode manual) Connect the phone to PC using USB cable Install phone drivers (only if the phone is connected for the first time). Select "HISILICON" platform from the tab menu in the upper left side of the software Wait for 10 seconds Go to "Unlock" tab Select "Android Adapter PCUI". If there is no such port, select "Comneon Mobile High-speed Modem" Press "Unlock" button The message "Unlock done… OK" indicates that procedure has been completed successfully Disconnect the handset A phone is unlocked SigmaKey 2.33.06 HiSi: Direct unlock Connecting.... Android Adapter PCUI (COM106), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 5/18/2016, USB\Vid_12D1&Subclass_13&Prot_22 Firmware: System 8.0.0.046(0C6A), Date: Mon Jun 4 19:37:59 CST 2018, Provider: kddiau/jp Boot Version: System 8.0.0.046(0C6A)_BOOT, FastBoot Version: Chipset-dallas8.0.0.001(02Q4)_FASTBOOT Recovery Version: (unknow), System Version: System 8.0.0.046(0C6A) Removing firmware protection....Done Software IMEI1: 86856503???????? Software IMEI2: 000000000000000 Unlocking phone...Done Restarting phone...Done |
The Following User Says Thank You to Jhilon For This Useful Post: |
