03-26-2017, 20:02 | #3 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Enable Manufacture Mode Open the hidden device menu: dial "*#*#2846579#*#*" Select "Project Menu" -> "Background Settings" -> "USB Ports Settings" -> "Manufacture Mode" Internet connection has to be enabled, proxy disabled. Root is not required Select "Qualcomm" platform from the tab menu in the upper left side of the software "Phone model" dropdown box has to be set to "Autodetect" Go to "Unlock" tab Connect your device to PC with USB cable Install required Huawei smartphone driver (only if the phone is connected for the first time) Select "DBAdapter Reserved Interface" port Press "Direct Unlock" button |
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post: |
