Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 07-22-2012, 14:38   #1 (permalink)
Member: 1774154
I need help, mb860 i cant connect...
HI ALL, SOMEONE CAN HELP ME, SINCE I AM TRYING TO CONNECT THE MOTOROLA MB860 ATT, BUT DO NOT RECOGNIZE ME THE BOX SIGMA... I'M DOING THE PROCEDURE THAT INDICATES TO THE UNLOCK DIRECT... AND EVEN SO DO NOT I CAN... WILL THAT HAVE TO CHANGE IT IN THE PHONE SETTINGS MENU... I HOPE YOUR HELP... Thank you
Old 07-23-2012, 09:00   #2 (permalink)
GSM_Support's Avatar
Member: 121052
@ compucel.unlock
Please tell me in what mode you connect phone to PC and what show you software ?
Best Regards
GSMServer team
Old 07-23-2012, 12:33   #3 (permalink)
florynel_gsm's Avatar
Member: 1624620
I have same problem with motorola mb860.i installed all drivers.i select in phone motorola phone portal,checked usb deblung,in program i go to qualcomm - unlock - serial port i select motorola at com port (com2) *motorola and when press connect motorola android phone say connecting...not found
What am I doing wrong?
Please help
Thanks
FLoryneL
Old 07-23-2012, 12:47   #4 (permalink)
mcandre's Avatar
Member: 239548
Qualcomm Manual - Sigma - MTK and Qualcomm-based phones flashing, unlocking, repair IMEI solution
read the manual
Old 07-23-2012, 13:01   #5 (permalink)
Member: 1624620
thanks for your qick replay bro but I already read this and I make what is write there but not work...
Old 07-23-2012, 14:07   #6 (permalink)
mcandre's Avatar
Member: 239548
All you have to do is:
- install correct drivers from here
- change usb mode to Motorola Phone portal (as far as I see you can do that easy)
- power the phone off
- connect the usb cable
- turn it on and wait for it to fully starts up - important
- press "Connect Motorola Android phone"
- press "unlock"
Old 07-23-2012, 14:28   #7 (permalink)
Member: 1624620
- press "unlock"
this I make and when I press connect motorola android phone say connecting...not found
Old 07-23-2012, 14:41   #8 (permalink)
Member: 121052
@ florynel_gsm
Try to un-install drivers for your phone manually from PC. After that install drivers for your phone.
Show screenhot or full operational log from software and screenshot from device manager, were I can see how your phone is detected there and on what port is it connected. . It may spread some light on your issue.
Best Regards
GSMServer team
Old 07-23-2012, 14:45   #9 (permalink)
GsmSolution.'s Avatar
Member: 1388679
Sonork: 1597516:GsmSolution
try with another computer.follow instruction in sigma box,i have encountered that problem also but manage to unlock the phone it was MB855
INSTRUCTION
Install Motorola drivers (only if the phone is connected for the first time)
Turn the phone Off
Connect the phone to PC with USB cable
Turn the phone on and wait for it to fully starts up
Select "Qualcomm" platform from the tab menu in the upper left side of the software
Go to "Unlock" tab
Press "Connect Motorola Android phone"
Press "Get unlock codes" button
Message "Reading unlock codes… Done" indicates that procedure was completed successfully
Disconnect the handset
Phone is unlocked
SCREENSHOT
BR,,
GsmSolution
Old 07-23-2012, 14:58   #10 (permalink)
mcandre's Avatar
Member: 239548
Do you use the latest version of SigmaKey? 1.10 or higher.
What operating system do you use?
Make these actions
and give me screen-shot of your device manager.
What do you see in Network adapters?
Old 07-23-2012, 15:59   #11 (permalink)
Member: 1624620
Make these actions
mb.JPG download - 2shared
Old 07-24-2012, 07:10   #12 (permalink)
Member: 1735771
Originally Posted by florynel_gsm View Post
Try disabling the TCP/IP firewall software (if any).
Old 07-25-2012, 12:29   #13 (permalink)
Member: 1624620
I try in another pc the problem same.I disabled the firewall.not work.
I don't know what to do...
In the program I don't find the Motorola Usb Networking,only Motorola AT COM Port
Thanks for all answers
FLoryneL
Old 07-25-2012, 12:58   #14 (permalink)
Member: 121052
@ florynel_gsm
Please check network setting and tell us what you see in IP for Motorola card.
Best Regards
GSMServer team
Old 07-25-2012, 16:23   #15 (permalink)
Member: 1624620
Originally Posted by GSM_Support View Post
@ florynel_gsm
Best Regards
GSMServer team
if I check correctly is 192.168.16.1
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.44271 seconds with 12 queries
