05-02-2018, 00:54 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: agadir oufla.
Member: 273511 Status: Offline Thanks Meter: 84 | infnix x571 repair imei not done . all in title. log Code: SigmaKey 2.27.17 ADB: Repair IMEI * daemon not running. starting it now * * daemon started successfully * ^ Android Composite ADB Interface Version: Linux version 3.18.35+ (rlk-buildsrv33@buildsrv-73) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Nov 14 17:23:32 CST 2017 Phone model: Infinix Infinix X571 Android 7.0; Firmware: NRD90M; Date: Sat Jul 1 21:38:36 CST 2017 Version: X571-H5311A-N-170701V151 Baseband Firmware: MOLY.LR9.W1444.MD.LWTG.MP.V110.5.P16, 2017/06/29 20:48 Baseband Processor: MT6753 Software IMEI1: 45xxxxxxxxxxxxx Driver start error! Software IMEI2: 24xxxxxxxxxxxxx Security area saved to \450617166882000_Infinix_Infinix X571_NRD90M_Sat Jul 1 213836 CST 2017.skb" Repaired IMEI1: 35xxxxxxxxxxxxx Repaired IMEI2: 35xxxxxxxxxxxxx Done Restarting phone...Done any hint on fixing it. tnx. |
05-02-2018, 07:49 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ jeanbrume, What an issue current phone originally had? Why did you perform IMEI Repair operation to it? Did you try to flash phone and repeat IMEI repair operation after that? Best Regards GSMServer team |
05-02-2018, 17:23 | #3 (permalink) |
Member: 273511 Status: Offline Thanks Meter: 84 | hi. yes exactly. flash firmware then (flash philztouch6_rocoverey flash su.zip) for root. & last IMEI repair . i assume "Driver start error!" is normal? thanks again for help. |
05-03-2018, 13:27 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ jeanbrume, Was problem solved? If no, check phone's hardware. In most cases "Driver start error!" error shows that the phone has hardware malfunctions. In some cases CPU requires to be reballed. Best Regards GSMServer team |
