07-16-2018, 15:18 | #1 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: earth
Member: 538815 Status: Offline Thanks Meter: 161 | nova 2i trying to downgrade but Quote:
phone conn is Android Adopter PCUI Phone problem is after update touch not working. nut in recovery its working | |
07-17-2018, 05:57 | #3 (permalink) |
Member: 538815 Status: Offline Thanks Meter: 161 | now i got this responce. Phone model: RNE-L22 Version: :RNE-L22 8.0.0.321(C636) Preparing...Unable to connect to the server. Please check your network. 224504471 Sigma dongle 2.28, Initializing...OK --------- 2018-07-17 12:54:42 --------- SigmaKey 2.28.04 HiSi: Write firmware (ADB) Writing flash...UPDATE.APP Firmware: Rhone_Global_EMUI8.0 This operation may brick the phone! Are you sure you want to proceed? [YES] Phone model: RNE-L22 Version: :RNE-L22 8.0.0.321(C636) Preparing...Unable to connect to the server. Please check your network. any help?? |
07-17-2018, 08:16 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ frooze_angel, Repeat operation once again and post results in a current thread. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
07-17-2018, 08:27 | #5 (permalink) | |
Member: 538815 Status: Offline Thanks Meter: 161 | Quote:
flashing fine now the server is ok. problem why i cant downgrade? | |
07-18-2018, 07:12 | #7 (permalink) |
Member: 538815 Status: Offline Thanks Meter: 161 | need help.... SigmaKey 2.28.04 HiSi: Write firmware DBAdapter Reserved Interface (COM47), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 5/18/2016, USB\Vid_12D1&Subclass_13&Prot_23 Writing flash...UPDATE.APP Firmware: RNE-L22C636B131 Hardware IMEI: 020304050607080 Writing flash SHA256RSA OK Writing flash CRC OK Writing flash CURVER OK Writing flash VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. |
07-18-2018, 09:00 | #11 (permalink) | |
the problem is device wont boot normally now only upgrade or fastboot mode only. the first problem is after customer update the phne restart and after update the touchscreen wont touch anymore. so i try to flash but now im stuck in here. | |
07-18-2018, 09:17 | #14 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Don't worry about Huawei original flash files. Search for your original firmware version there. Direct links from Huawei server. |
The Following User Says Thank You to mcandre For This Useful Post: |
07-18-2018, 09:29 | #15 (permalink) | |
okay il try and start firmware one by one | |
