Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 07-16-2018, 15:18   #1 (permalink)
frooze_angel's Avatar
Member: 538815
Thanks Meter: 161
nova 2i trying to downgrade but
it always give this error
--------- 2018-07-16 22:14:41 ---------
SigmaKey 2.28.04 HiSi: Enable downgrade
Connecting...Reboot phone and try again
phone conn is Android Adopter PCUI
Phone problem is after update touch not working.
nut in recovery its working
Old 07-17-2018, 00:47   #2 (permalink)
Member: 538815
Thanks Meter: 161
up this need solution stock at huwaei erecovery.
i can flash in fastboot but get error after flashing or failed in recovery
Old 07-17-2018, 05:57   #3 (permalink)
Member: 538815
Thanks Meter: 161
now i got this responce.
Phone model: RNE-L22
Version: :RNE-L22 8.0.0.321(C636)
Preparing...Unable to connect to the server. Please check your network.
224504471 Sigma dongle 2.28, Initializing...OK
--------- 2018-07-17 12:54:42 ---------
SigmaKey 2.28.04 HiSi: Write firmware
(ADB) Writing flash...UPDATE.APP
Firmware: Rhone_Global_EMUI8.0
This operation may brick the phone! Are you sure you want to proceed? [YES]
any help??
Old 07-17-2018, 08:16   #4 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
@ frooze_angel,
Repeat operation once again and post results in a current thread.
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 07-17-2018, 08:27   #5 (permalink)
Member: 538815
Thanks Meter: 161
Originally Posted by GSM_Support View Post
@ frooze_angel,
Best Regards
GSMServer team
flashing fine now the server is ok. problem why i cant downgrade?
Old 07-18-2018, 04:31   #6 (permalink)
Member: 538815
Thanks Meter: 161
Up, please check downgrade features not working
Old 07-18-2018, 07:12   #7 (permalink)
Member: 538815
Thanks Meter: 161
need help....
DBAdapter Reserved Interface (COM47), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 5/18/2016, USB\Vid_12D1&Subclass_13&Prot_23
Firmware: RNE-L22C636B131
Hardware IMEI: 020304050607080
Writing flash SHA256RSA OK
Writing flash CRC OK
Writing flash CURVER OK
Writing flash VERLIST ...Version mismatch.
Use "Enable downgrade" action first, then retry flashing.
Old 07-18-2018, 08:32   #8 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
"Enable downgrade" button is present on the Flash -> HiSi tab
Old 07-18-2018, 08:49   #9 (permalink)
Member: 538815
Thanks Meter: 161
trying to downgrade but always give this error
tried all port still same
Old 07-18-2018, 08:55   #10 (permalink)
Member: 1948608
Thanks Meter: 1,744
you cant Enable Downgrade while device in fastboot or upgrade Mode....it need Manufacture Mode...[ to do this Device must b Fully ON]
The Following User Says Thank You to -Mosin- For This Useful Post:
Old 07-18-2018, 09:00   #11 (permalink)
Member: 538815
Thanks Meter: 161
the problem is device wont boot normally now only upgrade or fastboot mode only.
the first problem is after customer update the phne restart and after update the touchscreen wont touch anymore.
so i try to flash but now im stuck in here.
Old 07-18-2018, 09:04   #12 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
The solution for you would be flashing this phone with the same firmware version using Upgrade mode (NOT fastboot mode)
Old 07-18-2018, 09:11   #13 (permalink)
Member: 538815
Thanks Meter: 161
yeah my last problem i almost downloaded files from support and already have 50gb of firmware and no one can be same of this one.
Old 07-18-2018, 09:17   #14 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
Don't worry about Huawei original flash files.
Search for your original firmware version there. Direct links from Huawei server.
The Following User Says Thank You to mcandre For This Useful Post:
Old 07-18-2018, 09:29   #15 (permalink)
Member: 538815
Thanks Meter: 161
okay il try and start firmware one by one
Page generated in 0.24095 seconds with 10 queries
