03-12-2020, 15:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | P30 Lite MAR-LX1A 9.1.0.275(C431E6R2P3) downgreade for FRP ? I have one P30 Lite MAR-LX1A for FRP remove with Firmware MAR-L21A 9.1.0.275(C431E6R2P3) Still can't remove FRP. SAFE MODE solution not work. Need to downgrade it. This is phone information: Code: read Huawei Model MAR-LX1A read Huawei build number MAR-L21A 9.1.0.275(C431E6R2P3) read FRP/User lock status FAILCommand not allowed read Bootloader locked/unlocked (bootloader) locked read Battery level (bootloader) 4335mv read Vendor/Country vendorcountry: hw/eea Code: SigmaKey 2.34.07b3 HiSi: Write firmware DBAdapter Reserved Interface (COM713), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 30.7.2015 г., USB\Vid_12d1&Subclass_13&Prot_23 Writing flash...UPDATE.APP Hardware IMEI: 020304050607080 Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST OK Writing flash BASE_VER OK Writing flash PACKAGE_TYPE OK Writing flash HISIUFS_GPT OK Writing flash XLOADER OK Writing flash FASTBOOT OK Writing flash HHEE OK Writing flash DTS OK Writing flash TRUSTFIRMWARE OK Writing flash FW_LPM3 OK Writing flash DTO OK Writing flash KERNEL OK Writing flash TEEOS OK Writing flash ISP_FIRMWARE OK Writing flash VECTOR OK Writing flash SENSORHUB OK Writing flash FW_HIFI OK Writing flash VBMETA OK Writing flash MODEMNVM_UPDATE OK Writing flash MODEMNVM_CUST OK Writing flash RECOVERY_RAMDISK OK Writing flash RECOVERY_VENDOR OK Writing flash RECOVERY_VBMETA OK Writing flash PREAS OK Writing flash PREAVS OK Writing flash ERECOVERY_KERNEL OK Writing flash ERECOVERY_RAMDISK OK Writing flash ERECOVERY_VENDOR OK Writing flash ERECOVERY_VBMETA OK Writing flash ENG_VENDOR OK Writing flash ENG_SYSTEM OK Writing flash CACHE OK Writing flash SYSTEM OK Writing flash CUST OK Writing flash MODEM_FW OK Writing flash HISEE_IMG OK Writing flash HISEE_FS OK Writing flash VENDOR OK Writing flash ODM OK Writing flash PRODUCT OK Writing flash PATCH OK Writing flash USERDATA OK Writing flash VERSION OK Writing flash PRELOAD OK Done Code: SigmaKey 2.34.07b3 HiSi: Write firmware DBAdapter Reserved Interface (COM713), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 30.7.2015 г., USB\Vid_12d1&Subclass_13&Prot_23 Writing flash...UPDATE.APP Hardware IMEI: 020304050607080 Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. Code: SigmaKey 2.34.07b3 HiSi: Enable downgrade DBAdapter Reserved Interface (COM713), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 30.7.2015 г., USB\Vid_12d1&Subclass_13&Prot_23 Hardware IMEI: 020304050607080 Enabling firmware downgrade...Done Write firmware Code: ENABLE DOWNGRADE Power the phone ON Set the phone to manufacture mode Open HiSilicon tab and go to Flash bookmark Select "Android Adapter PCUI" port Press “ENABLE DOWNGRADE” button You need to reflash the phone after using this feature You may use it: To downgrade phone’s firmware version (for example, downgrade from higher to lower one). How to do this: Enable downgrade in Manufacture mode. Reflash the device in upgrade mode: vol+vol- and connect USB cable. To change phone’s localization (for example, to switch from Operator1 to Operator2). How to do this: Change provider settings (in manufacture mode). Enable downgrade (in manufacture mode). Flash the phone with the firmware that fits the selected provider settings (using upgrade mode: vol+vol- and connect USB cable). I try 2 ways for downgrade: 1: with Vol- + Vol+ and USB connect phone to upgrade mode. press downdrage button in Sigmakey and then try lower firmware. - get error then reflash phone to MAR-L21A 9.1.0.275(C431E6R2P3) 2: with Vol- + Vol+ and USB connect phone to upgrade mode. flash MAR-L21A 9.1.0.275(C431E6R2P3) and when start flash SYSTEM (this is ~25%) remove USB cable. hard close Sigmakey (from Task Manager), and then with Sigmakey try to flash lower firmware. - get error The firmwares that I try are: P30 Lite ( Dual ) MAR-LX1A 9.1.0 (C185) Reset Frp (Downgrade Firmware) P30 Lite ( Dual ) MAR-LX1A MAR-L21 hw eea Marie-L21A 9.0.1.155(C431E6R2P3) Firmware 9.0.0 r3 EMUI9.0.1 05015UBC How to downdrage this MAR-LX1A with MAR-L21A 9.1.0.275(C431E6R2P3) firmware ? |
03-12-2020, 15:17 | #2 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
03-12-2020, 15:32 | #3 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | I you read again will see. When I try to write lower firmware every time I get this error: Code: SigmaKey 2.34.07b3 HiSi: Write firmware DBAdapter Reserved Interface (COM713), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 30.7.2015 г., USB\Vid_12d1&Subclass_13&Prot_23 Writing flash...UPDATE.APP Hardware IMEI: 020304050607080 Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. |
03-12-2020, 15:44 | #4 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Important: use this manual for your phone "Enable downgrade on the latest Huawei smartphones" Code: Important! Read original phone firmware version from Fastboot mode or in the phone's menu
If you did everything correctly, in accordance to manuals, then try another flash file. For example, this one: 9.0.1.120(C431E6R2P3) Last edited by mcandre; 03-12-2020 at 15:53. |
03-12-2020, 16:05 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ Svetli, At the moment MAR-LX1a phone model is not supported for current operation. Please wait for upcoming SigmaKey releases. mcandre have mentioned how to downgrade version and run operation to the supported devices. Best Regards GSMServer team |
03-12-2020, 16:19 | #6 (permalink) | |
Member: 1191 Status: Offline Thanks Meter: 128 | Quote:
Code: SigmaKey 2.34.07b3 HiSi: Write firmware DBAdapter Reserved Interface (COM713), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 30.7.2015 г., USB\Vid_12d1&Subclass_13&Prot_23 Writing flash...UPDATE.APP Hardware IMEI: 020304050607080 Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. | |
03-12-2020, 16:21 | #7 (permalink) | |
Ok, I will wait. I will try when new Sigmakey veriosn is out. This phone wait 2-3 weeks. | |
The Following User Says Thank You to Svetli For This Useful Post: |
