11-11-2023, 17:39 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: italy
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | possible downgrade p40 lite? SigmaPlus 1.00.01 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.32 V Phone model: CDY-AN00 Build number: CDY-AN00 3.0.0.165(C00E160R5P2) Vendor/Country: all/cn System version: Skipped Android version: 10 Base version: CDY-LGRP1-CHN 103.0.0.165 Custom version: CDY-AN00-CUST 103.0.0.160(C00) Preload version: CDY-AN00-PRELOAD 103.0.0.2(C00R5) Huawei-Over-the-Air info: C_version: C00 D_version: D000 PLMN: 22250 BoardID: 10940 DeviceName: CDY-AN00 |
11-12-2023, 00:00 | #2 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,439 | First, make a backup of this phone. Later, flash a lower version of the firmware from the same region. |
11-18-2023, 15:27 | #3 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | I forgot to turn off the wifi and at night it updated again, now I have this security SigmaPlus 1.00.01 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.39 V Phone model: CDY-AN00 Build number: CDY-AN00 3.0.0.171(C00E160R5P2) Vendor/Country: all/cn System version: Skipped Android version: 10 Base version: CDY-LGRP1-CHN 103.0.0.171 Custom version: CDY-AN00-CUST 103.0.0.160(C00) Preload version: CDY-AN00-PRELOAD 103.0.0.2(C00R5) Huawei-Over-the-Air info: C_version: C00 D_version: D000 PLMN: 22250 BoardID: 10940 DeviceName: CDY-AN00 I'm not able to downgrade, I'm not finding the right firmware, I had loaded this version Base Package: CDY-LGRP1-CHN 102.0.0.165 Cust Package: CDY-AN00-CUST 102.0.0.165(C00) Preload PKG : CDY-AN00-PRELOAD 102.0.0.6(C00R5) but I get an error telling me that the file does not correspond to the tel, Can someone tell me the right firmware thanks!!!!! |
11-18-2023, 16:38 | #5 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | honestly I didn't want to open the phone to do the manual testpoint, do you have some files to do it automatically without opening the phone |
11-20-2023, 10:43 | #7 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | after many attempts I managed to downgrade with Hisuite using a VPN, now I'm back with EMUI SigmaPlus 1.00.01 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.39 V Phone model: CDY-AN00 Build number: CDY-AN00 10.1.1.215(C00E210R5P1) Vendor/Country: all/cn System version: Skipped Android version: 10 Base version: CDY-LGRP1-CHN 10.1.1.215 Custom version: CDY-AN00-CUST 10.1.1.210(C00) Preload version: CDY-AN00-PRELOAD 10.1.1.1(C00R5) Huawei-Over-the-Air info: C_version: C00 D_version: D000 PLMN: 22250 BoardID: 10940 DeviceName: CDY-AN00 now I wanted to change region but I get an error I don't understand why SigmaPlus v.1.00.01 New version 1.00.02 is available on www.sigmakey.com. We strongly recommend to update SigmaPlus! 282266458 Sigma+ dongle 3.00, Initializing...OK --------- 2023-11-20 10:31:16 --------- SigmaPlus 1.00.01 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM190), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18/05/2016, USB\Vid_12D1&Subclass_13&Prot_23 If the operation fails with Full_OTA_update firmware type, use SD_update file type. Hardware IMEI: 020304050607080 Flash file D:\FIRMWARE HUAWEI\P40 LITE 5G\update_full_base\UPDATE.APP Please send C:\Users\PC\Documents\SigmaPlus\temporary backup\0282266458\CindyN-LGRP1-CHN 10_1_1_215.skb file to [email protected] Data retention error |
11-20-2023, 10:47 | #8 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | SigmaPlus 1.00.01 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM190), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18/05/2016, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file D:\FIRMWARE HUAWEI\P40 LITE 5G\Huawei P40 Lite 5G [ Honor 30S ] CDY-NX9A hw eu CDY-N29 Cindy-N29A 10.1.1.215(C432E2R4P1)_Firmware_EMUI10.1.1_05016TW N\Software\dload\update_sd_base\UPDATE.APP Version mismatch. Use "Enable downgrade" action first, then retry flashing. |
11-20-2023, 11:32 | #9 (permalink) | |
Member: 21077 Status: Offline Thanks Meter: 116,439 | Quote:
In case of newer security zone versions, the software test point won't function. It's advisable to use the hardware test point for new security versions. | |
11-20-2023, 13:38 | #10 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | t would be possible to tell the developers to add new security features like this in the next updates, it would be a good update, no longer open the phone to do testpoints, don't abandon Huawei!! |
The Following 2 Users Say Thank You to salvo1278 For This Useful Post: |
