01-21-2018, 19:14 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | xt1072 frp cnot remove SigmaKey v.2.27.02 Sigma dongle 2.27, Initializing...OK Pack 1: Activated Pack 2: Activated Pack 3: Activated --------- 2018-01-21 18:49:16 --------- SigmaKey 2.27.02 ADB: Connect Motorola Android phone Getting info...Skipped Connecting......Done PLEASE RESTART PHONE MANUALLY! Read the manual at the official site www.sigmakey.com for details. --------- 2018-01-21 18:51:54 --------- SigmaKey 2.27.02 ADB: Connect Motorola Android phone Getting info...Skipped Connecting......Done PLEASE RESTART PHONE MANUALLY! Read the manual at the official site www.sigmakey.com for details. --------- 2018-01-21 18:52:57 --------- SigmaKey 2.27.02 ADB: Remove FRP * daemon not running. starting it now * * daemon started successfully * Mot Composite ADB Interface Cancelled i see the manual but not succes |
01-22-2018, 08:41 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ genci titi 2002, Check video tutorial on how to perform FRP Remove operation here. Don't forget to connect phone in a FastBoot mode. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
01-22-2018, 08:58 | #3 (permalink) | |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Quote:
Moto xt1072 not adb enabled on step2 by manual from support. After step 1, I power off phone, boot in fastboot mode, when choose factory mode, moto power on but adb not enabled. cnot enable developer mode and when type build number not typed after activate the menu with baypass method | |
01-22-2018, 09:12 | #4 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | maybe is hardware problem i try and another tools but when soft ask usb on phone not see allow usb debuginig |
01-23-2018, 10:41 | #5 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2742454 Status: Offline Thanks Meter: 0 | I can Confirm as well, I tried over 3 phones (XT1072) and all have the same issue log. after pressing "connecting Motorola Phone" while on Factory Mode The next entry into Factory Mode the phone needs to be connected again. while the Mot Composite is found after connection,I can't accept the RSA Fingerprint (Allow USB debugging) until i access the Factory Mode a second time,but the option is not possible because, once you attempt the second Factory Mode it disconnects the Motorola Connection and the Mot Composite driver is gone from the list of drivers until you reconnect the Motorola Connection option. |
