02-13-2013, 03:14 | #46 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | micromax a110 hard reset 1 volume up + volume down + power switch 2 volume up 3 recovery 4 wipe data/factory reset BRO, PRASAD |
The Following 2 Users Say Thank You to cellcare prasad For This Useful Post: |
02-13-2013, 03:19 | #47 (permalink) |
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | CALLBAR A1 HARDRESET 1 volume down + power switch press 30-sec on the screen recovery menu 2 Use volume button select wipe factory reset (press power button) 3 Yes (or) no u select yes (press power button ) 100% hard reset ur device |
02-20-2013, 09:02 | #51 (permalink) |
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | no hard reset for celkon ct-3 only flash with original rom can remove google account |
03-02-2013, 08:46 | #53 (permalink) |
Freak Poster Join Date: Jan 2013 Location: coimbathore,tamilnadhu
Member: 1862439 Status: Offline Sonork: 1625375:karthik Thanks Meter: 18 | please help me my hand set problem is pattern lock model:rokea r9300 cpu type:spd any one help pls i try to hard reset vol+,vol_,menu,power button its come fast boot mode |
03-03-2013, 19:05 | #54 (permalink) | |
Major Poster Join Date: Apr 2010
Member: 1278728 Status: Offline Thanks Meter: 7 | Quote:
first you must install android sdk or adb then enter fasboot open cmd go to platform-tools write fastboot-w write fastboot reboot you done | |
03-07-2013, 12:57 | #55 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ropar
Member: 358277 Status: Offline Thanks Meter: 476 | karbonn a2 hard reset here is process of hard reset karbonn a2. 1.press vol up + power key . then u see triangle icon on screen . 2.then touch on touch screen left sign key . 3. then u will see all options for wipe ur handset. 4. to select any option press home key on touch . 5. to go up & down u can use volume key but to select home key on touch . |
The Following User Says Thank You to jai2008 For This Useful Post: |
03-14-2013, 14:57 | #58 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | How to hard reset mi 424 |
03-15-2013, 08:24 | #59 (permalink) |
Junior Member Join Date: Jun 2011 Location: gujrat jamnagar
Member: 1607525 Status: Offline Sonork: hm7302 Thanks Meter: 2 | micromax a57 hard reset sucsees volume up + power on hold 10 second 100000% work |
The Following User Says Thank You to hemal192 For This Useful Post: |
