01-13-2015, 15:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | [100% Safe] Pattern Unlock by Moiz Khan Using Volcano (No Need USB Debug) Hello All Volcano Box Lovers ! From Today I'll Provide All Of You 100% Safe & Successfull Pattern Unlock Procedures (Using Volcano Box) NO NEED USB DEBUGGING ON Please Keep This Thread Clean !! !! WARNING !! Use These Methods & Volcano Tool Versions Only For The Given Model. Dont Use The Same Method For Any Other Model. Dont post "THANKS/GOOD" Posts Use Thanks Button Instead Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 09:18. |
The Following 43 Users Say Thank You to Moiz Khan For This Useful Post: |
01-13-2015, 16:10 | #2 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A72 100% Safe Pattern Unlock Using Volcano Micromax A72 Pattern Unlock Using Volcano NOTE - All MTK Drivers Must be Installed Method - Code: * Open Volcano Box v2.7.2 * Open Android Tab * Go to USB Mode Tab * Tick "Format" & Select "Auto" * Tick "Usb Mode" & Press "Start" Button * Power Off Phone * With Battery inserted connect phone to USB Cable Your Phone will get Formatted Successfully. >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:15. Reason: Tool link shared |
The Following 13 Users Say Thank You to Moiz Khan For This Useful Post: |
01-13-2015, 16:44 | #3 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A26 Pattern Unlock Using Volcano [100% Safe] Micromax A26 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Open Volcano Box v2.1.4 * Connect Phone on Volcano Main Cable (Attach Power Cables Also) * Open SPD Tab * Select "Built-in-Boot_14(6820/8810)" * Tick "Format" * Tick "Auto-detect pinouts" & set Baudrate = 115200 * Press "Start" Button Your Phone will get Formatted Successfully. >> Download Volcano 2.1.4 From Here << Best Regards - Smk™ © Last edited by Moiz Khan; 01-13-2015 at 16:55. |
The Following 9 Users Say Thank You to Moiz Khan For This Useful Post: |
01-13-2015, 16:45 | #4 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A34 Pattern Unlock Using Volcano [100% Safe] Micromax A34 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Open Volcano Box v2.1.4 * Connect Phone on Volcano Main Cable (Attach Power Cables Also) * Open SPD Tab * Select "Built-in-Boot_14(6820/8810)" * Tick "Format" * Tick "Auto-detect pinouts" & set Baudrate = 115200 * Press "Start" Button Your Phone will get Formatted Successfully. >> Download Volcano 2.1.4 From Here << Best Regards - Smk™ © Last edited by Moiz Khan; 01-13-2015 at 16:56. |
The Following 8 Users Say Thank You to Moiz Khan For This Useful Post: |
01-13-2015, 16:49 | #5 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A62 Pattern Unlock Using Volcano [100% Safe] Micromax A62 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Open Volcano Box v2.1.4 * Connect Phone on Volcano Main Cable (Attach Power Cables Also) * Open SPD Tab * Select "Built-in-Boot_14(6820/8810)" * Tick "Format" * Tick "Auto-detect pinouts" & set Baudrate = 115200 * Press "Start" Button Your Phone will get Formatted Successfully. >> Download Volcano 2.1.4 From Here << Best Regards - Smk™ © Last edited by Moiz Khan; 01-13-2015 at 16:56. |
The Following 10 Users Say Thank You to Moiz Khan For This Useful Post: |
01-14-2015, 08:26 | #6 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A27 Pattern Unlock Using Volcano [100% Safe] Micromax A27 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Remove Battery and then Insert it again in the phone * Press Power Button for 2-3 seconds then quickly press Volume Down Button (Phone will come in Fastboot mode) * Connect Phone to USB Cable. (Fastboot drivers must be installed) * Open Volcano Box v2.7.2 * Open Android Tab * Go to FASTBOOT Tab * Select "Wipe Data" * Tick "Usb Mode" & Press "Start" Button * Your Phone will get Wiped Successfully. * After this, Tick "Exit Fastboot" & Press "Start" Button Remove Phone, Its Unlocked Now >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << DOWNLOAD SPD FASTBOOT DRIVERS FROM HERE Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:16. Reason: tool link shared |
The Following 4 Users Say Thank You to Moiz Khan For This Useful Post: |
01-14-2015, 08:29 | #7 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A28 Pattern Unlock Using Volcano [100% Safe] Micromax A28 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Remove Battery and then Insert it again in the phone * Press Power Button for 2-3 seconds then quickly press Volume Down Button (Phone will come in Fastboot mode) * Connect Phone to USB Cable. (Fastboot drivers must be installed) * Open Volcano Box v2.7.2 * Open Android Tab * Go to FASTBOOT Tab * Select "Wipe Data" * Tick "Usb Mode" & Press "Start" Button * Your Phone will get Wiped Successfully. * After this, Tick "Exit Fastboot" & Press "Start" Button Remove Phone, Its Unlocked Now >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << DOWNLOAD SPD FASTBOOT DRIVERS FROM HERE Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:17. Reason: tool link shared |
The Following 2 Users Say Thank You to Moiz Khan For This Useful Post: |
01-14-2015, 08:29 | #8 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A35 Pattern Unlock Using Volcano [100% Safe] Micromax A35 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Remove Battery and then Insert it again in the phone * Press Power Button for 2-3 seconds then quickly press Volume Down Button (Phone will come in Fastboot mode) * Connect Phone to USB Cable. (Fastboot drivers must be installed) * Open Volcano Box v2.7.2 * Open Android Tab * Go to FASTBOOT Tab * Select "Wipe Data" * Tick "Usb Mode" & Press "Start" Button * Your Phone will get Wiped Successfully. * After this, Tick "Exit Fastboot" & Press "Start" Button Remove Phone, Its Unlocked Now >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << DOWNLOAD SPD FASTBOOT DRIVERS FROM HERE Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:17. Reason: tool link shared |
The Following User Says Thank You to Moiz Khan For This Useful Post: |
01-14-2015, 08:30 | #9 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A36 Pattern Unlock Using Volcano [100% Safe] Micromax A36 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Remove Battery and then Insert it again in the phone * Press Power Button for 2-3 seconds then quickly press Volume Down Button (Phone will come in Fastboot mode) * Connect Phone to USB Cable. (Fastboot drivers must be installed) * Open Volcano Box v2.7.2 * Open Android Tab * Go to FASTBOOT Tab * Select "Wipe Data" * Tick "Usb Mode" & Press "Start" Button * Your Phone will get Wiped Successfully. * After this, Tick "Exit Fastboot" & Press "Start" Button Remove Phone, Its Unlocked Now >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << DOWNLOAD SPD FASTBOOT DRIVERS FROM HERE Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:18. Reason: tool link shared |
01-14-2015, 08:32 | #10 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A40 Pattern Unlock Using Volcano [100% Safe] Micromax A40 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Remove Battery and then Insert it again in the phone * Press Power Button for 2-3 seconds then quickly press Volume Down Button (Phone will come in Fastboot mode) * Connect Phone to USB Cable. (Fastboot drivers must be installed) * Open Volcano Box v2.7.2 * Open Android Tab * Go to FASTBOOT Tab * Select "Wipe Data" * Tick "Usb Mode" & Press "Start" Button * Your Phone will get Wiped Successfully. * After this, Tick "Exit Fastboot" & Press "Start" Button Remove Phone, Its Unlocked Now >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << DOWNLOAD SPD FASTBOOT DRIVERS FROM HERE Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:18. Reason: tool link shared |
01-14-2015, 08:37 | #11 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A55 Pattern Unlock Using Volcano [100% Safe] Micromax A55 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Remove Battery and then Insert it again in the phone * Press & Hold HOME button and Connect Phone to USB Cable (Phone will come in Download mode) >> This is Fastboot Mode (Fastboot drivers must be installed in PC) * Open Volcano Box v2.7.2 * Open Android Tab * Go to FASTBOOT Tab * Select "Wipe Data" * Tick "Usb Mode" & Press "Start" Button * Your Phone will get Wiped Successfully. * After this, Tick "Exit Fastboot" & Press "Start" Button Remove Phone, Its Unlocked Now >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << DOWNLOAD SPD FASTBOOT DRIVERS FROM HERE Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:19. Reason: tool link shared |
01-14-2015, 08:47 | #12 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Micromax A65 Pattern Unlock Using Volcano [100% Safe] Micromax A65 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Remove Battery and then Insert it again in the phone * Press Power Button for 2-3 seconds then quickly press Volume Down Button (Phone will come in Fastboot mode) * Connect Phone to USB Cable. (Fastboot drivers must be installed) * Open Volcano Box v2.7.2 * Open Android Tab * Go to FASTBOOT Tab * Select "Wipe Data" * Tick "Usb Mode" & Press "Start" Button * Your Phone will get Wiped Successfully. * After this, Tick "Exit Fastboot" & Press "Start" Button Remove Phone, Its Unlocked Now >> Download Volcano 2.7.2 (Part 1) From Here << >> Download Volcano 2.7.2 (Part 2) From Here << DOWNLOAD SPD FASTBOOT DRIVERS FROM HERE Best Regards - Smk™ © Last edited by Moiz Khan; 01-14-2015 at 13:20. |
01-14-2015, 08:50 | #13 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | INTEX Aqua Star Pattern Unlock Using Volcano [100% Safe] INTEX Aqua Star 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Open Volcano Box v2.1.4 * Connect Phone on Volcano Main Cable (Attach Power Cables Also) * Open SPD Tab * Select "Built-in-Boot_14(6820/8810)" * Tick "Format" * Tick "Auto-detect pinouts" & set Baudrate = 115200 * Press "Start" Button Your Phone will get Formatted Successfully. >> Download Volcano 2.1.4 From Here << Best Regards - Smk™ © |
01-16-2015, 07:19 | #14 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Karbonn A1+ Pattern Unlock Using Volcano [100% Safe] Karbonn A1+ 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Open Volcano Box v2.1.4 * Connect Phone on Volcano Main Cable (Attach Power Cables Also) * Open SPD Tab * Select "Built-in-Boot_14(6820/8810)" * Tick "Format" * Tick "Auto-detect pinouts" & set Baudrate = 115200 * Press "Start" Button Your Phone will get Formatted Successfully. >> Download Volcano 2.1.4 From Here << Best Regards - Smk™ © |
01-16-2015, 07:20 | #15 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Karbonn A3* Pattern Unlock Using Volcano [100% Safe] Karbonn A3* 100% Safe Pattern Unlock Using Volcano NOTE - All SPD Drivers Must be Installed Method - Code: * Open Volcano Box v2.1.4 * Connect Phone on Volcano Main Cable (Attach Power Cables Also) * Open SPD Tab * Select "Built-in-Boot_14(6820/8810)" * Tick "Format" * Tick "Auto-detect pinouts" & set Baudrate = 115200 * Press "Start" Button Your Phone will get Formatted Successfully. >> Download Volcano 2.1.4 From Here << Best Regards - Smk™ © |
