02-04-2014, 10:32 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Find KCOLO pinout on PCB inside..and short it with GND... your handset will get detected. then flash it. bR. Smk |
The Following User Says Thank You to Moiz Khan For This Useful Post: |
02-06-2014, 12:37 | #6 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1740134 Status: Offline Thanks Meter: 52 | |
02-06-2014, 16:24 | #8 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @ CLIFFORD25502 its problem in phone if phone connect with PC then you do job with volcano if not then not with volcano i see also your post in other section same issue BR Qaisar Mahmood |
06-14-2017, 10:51 | #10 (permalink) |
Insane Poster Join Date: Jul 2005 Location: Varna, Bulgaria Age: 51
Member: 161384 Status: Offline Sonork: 100.1657922 Thanks Meter: 3 | Which points to be used as test point? Please guide me. So far no luck with keys pwr vol+ vol-. If anyone knows the test point please share. There is a picture of the board here http://forum.gsmhosting.com/vbb/f317...icked-2043516/ but which one is the test point? |
06-14-2017, 11:50 | #11 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | @ivolom Try one by one to connect test points with GROUND of board.It should connect with one of it.Best of luck BR. Sehar GPG Team |
