05-08-2014, 08:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Analysis flash internal data fail !! HELP RESET GMAIL Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 0.97 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM10), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00C800BC90555400 FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),1536k(2ndbl),1280k(params),1536k(vm jaluna),5m(modem),3840k(fixnv),3840k(backupfixnv), 5120k(dsp),3840k(runtimenv),8m(boot),10m(recovery) ,230m(system),154m(userdata),60m(cache),256k(misc) ,1m(boot_logo),1m(fastboot_logo),3840k(productinfo ),512k(kpanic),512k(simlock),10m(intmemory) Analysis flash internal data fail. >>>>Please read the phone partition. |
05-08-2014, 08:07 | #2 (permalink) | |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Quote:
05-08-2014, 08:31 | #4 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Philippines
Member: 1494304 Status: Offline Sonork: 100.1606186 Thanks Meter: 108 | if usb debugging enabled try to root ang wipe all using volcano android tool tab! connect power on phone then click, is adb mode? some information shows if your unit is debug enable |
05-08-2014, 08:33 | #5 (permalink) | |
try this then post result | |
05-08-2014, 08:52 | #6 (permalink) | |
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
on my phone ADB is off, also the link you posted looks like your phone is MTK Android, , | |
05-08-2014, 10:11 | #8 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | This process works for both spd and mtk phones provided your usb debugging menu is switched on before the phone became locked. The process you followed in your initial post that give you the result FLASH ANALYSIS FAIL mean your phone is not supported by Volcano presently so do not format your phone with Volcano. This is a forceful way of removing google lock or gmail lock from phones (spd and mtk) with Volcano when usb debugging is off. |
05-08-2014, 10:18 | #9 (permalink) | |
thank you very much for your reply , so is there anyway i can solve this gmail problem? can you tell me step by step please, | |
05-10-2014, 07:26 | #13 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Quote:
If it gives message - "Analysis Flash internal data Successfully" then you can do format without any risk. If it gives message - "Analysis Flash internal data fail" then its risky to format the phone (If still you want to format, Do format on your risk.) Format only if you have working backup or firmware available at your collection. We recommend..dont do format. If dead, flashing is the only solution. bR. Smk | |
