10-07-2014, 13:49 | #1 (permalink) |
Insane Poster Join Date: Dec 2013
Member: 2093446 Status: Offline Thanks Meter: 4 | can not connect mstar device Detection D+/D- with 0.97 seconds! Analyzing USB device, please wait... Found [MSTAR]USB device:GCREADER USB Device,(VID_1B20&PID_0300) Setting... >>Set the Pinouts failed,please reconnect and try again! at this time device is opened as a mass storage I know that this is driver issue but i cant solve. plz help also i test reset pinouts but shows this message: Reset USB device and search it... >>Time-out, try again, or re-plug your phone, or re-defined pinouts. tnx |
10-07-2014, 16:07 | #4 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hi ... Install Mstar Driver Fist .. Use Modify Cable .. No Need Amy Power or Buttery .. Run Volcano Go to Mster Tab .. Just Connect Modify Cable .. Port will Change to USB mode .. No Do Read/Write .. Wbr, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
10-07-2014, 19:54 | #6 (permalink) | |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
Wbr, AniAXN | |
10-08-2014, 07:09 | #7 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Quote:
Do as said - *Tick Read/Write Flash *Remove Tick from "Auto-detect pinouts" *Press Reset Pinouts button *Press RUN post report here . . bR. Smk | |
