12-25-2013, 18:04 | #3 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | @ Armkar ..... Brother this is spd 8810 chip... dont use Volcano main cable detect the chip... Use Only USB cable ... Just Do this step ... Run Latest Volcano ... Install Spd Driver ... Go to Spd Tab ... Select Boot_14 ... trik Auto-detect pinout ... Select Read info ... Connect usb cable to phone & do Run ... When Software says " Analyzing usb Device" Press boot key ...(if you have modify cable no need press any boot key) If Flash chip supported Do Format ... your own Risk .. BR AniAXN Last edited by AniAxn; 12-25-2013 at 18:11. |
12-25-2013, 19:13 | #4 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: Armenia, Armavir
Member: 616204 Status: Offline Thanks Meter: 26 | Quote:
12-25-2013, 19:16 | #5 (permalink) | |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Quote:
bro , you connect phone via usb cable direct with pc and trying to find pinouts , this is imposable thing you can detect pinouts when phone will connected with volcano box cable and if you want connect via usb cable then untick mark Auto detect pinouts connect phone in off condition with boot key or with modified cable then select spd port (as you show in screenshot ) then select jon which you want and press run button and post result | |
12-26-2013, 16:04 | #6 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | ı same problem Mr sweet4hamza my phone google account removed how to connect phone please step by step write phone can not formated only google account removed please help me B:R |
12-26-2013, 19:35 | #7 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | see my above post and after use one opion , like in screenshot show you read info you again put out usb cable and battery and need to again connect phone with boot or etc as you try first time in every time after use any option you need reconnect phone |
12-27-2013, 08:29 | #8 (permalink) | |
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
http://forum.gsmhosting.com/vbb/f723...stafa-1754964/ | |
