06-03-2015, 13:40 | #2 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Posted on Foume Hundred Times Follow This Steps Select Readed File Format Write Read File Ones Again Format After Format Power On Phone With Volcano Eagle Eye .. Press Power Key 2 - 3 Minutes Until Phone Gets Power On |
06-04-2015, 12:50 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Quote:
But writing stop at 0%: I try on different speeds: 921600-460800-230400-115200 - same result. Help to revive phone - I just read dump from working phone for collection. | |
06-04-2015, 13:12 | #4 (permalink) | |
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
06-04-2015, 16:01 | #5 (permalink) |
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | @Dr_Wolodya upload here you readed dump..which you read 1st time..after mobile dead. BR |
The Following User Says Thank You to laxmi kamlesh For This Useful Post: |
06-04-2015, 17:52 | #6 (permalink) | |
Thanks for your answer. Tomorrow I will upload. | |
06-04-2015, 18:05 | #8 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Bro its spd driver issue nothing else .plz change spd drivers 1.5.6.1 and use modified usb cable all will be fine. |
The Following User Says Thank You to amn32 For This Useful Post: |
06-04-2015, 18:17 | #9 (permalink) | |
But phone die just after reading!!!!!! I don't have "Same Other Good Work Mobile" and I can't read fullflash from "Same Other Good Work Mobile" using Volcano 2.7.2 because I afraid that "Same Other Good Work Mobile" will become dead too. I have one fullflash, I have one dead mobile and I have just one Volcano for servicing chinese phones. | |
06-04-2015, 18:50 | #10 (permalink) | |
amn32, please, upload here spd drivers 1.5.6.1 for 32 bit Windows 8 (Driver Signature already turned off). Thanks | |
06-04-2015, 18:55 | #11 (permalink) | |
The Following User Says Thank You to zoneofash For This Useful Post: |
06-04-2015, 19:53 | #12 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | i have got this type of issue two times,,,,,, if it stops at writing(0),,,, then firmware is damaged,,,, only way,,,, flash the phone,,, if u cant get any flash files for ur mobile just contact me via pm,, i will give some other ideas.. to revive ur phone..... |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
06-05-2015, 09:38 | #13 (permalink) | |
Log: Code: Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 0,94 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) D+ = 3, D- = 2 Setting... Find USB device:SPRD U2S Diag (COM25), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Blo~ CPU TYPE:SC6531 [65310001] FLASH ID: 00EF004000160000 Flash Type: SF_W25Q32BV Size:0x400000(4MB) Reading completed. >>The data has been saved in D:\Mobile\MTK!!!!!!\Firmware\Cherry mini5130\_20150603_142251_FullFlash.bin, size: 4 M. | |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
06-05-2015, 09:49 | #14 (permalink) |
Member: 1873645 Status: Offline Thanks Meter: 977 | @Dr_Wolodya i have sent my contact id..check your PM. I need to connect with you. when you have free time. till i will check your file where is mistek. BR |
