01-29-2014, 16:01 | #1 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1284113 Status: Offline Thanks Meter: 0 | China i9500 clone bricked - Single SIM - Test Point? I just received my new Volcano box and Im trying to repair this chinese clone i9500. When I connect the USB to my laptop it is discovered as Alcatel mplah mpla driver. I used the box to read flash and it cannot be detected: Available Ports:COM3 COM13 Detection initiated, connect the phone and power on it... Vcc: null Gnd: 5 Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... Failed to detect. >>Pinouts are not fonud (typo :P)! Can you please identify Test-point from the picture or guide me how to repair this brick? BR, George |
01-29-2014, 16:01 | #2 (permalink) |
Member: 1284113 Status: Offline Thanks Meter: 0 | The phone is this one: GT-i9500 S4 (5", 1280*720, 1Gb RAM, 4Gb ROM , 6589) ? 18 ? Forum.China-iPhone.Ru and the PCB photo is found here: https://app.box.com/s/yztmozez6xpykv4jexvi |
01-29-2014, 18:08 | #3 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | as i seen , you did not know how to connect phone with box you already installed Alcatel mtk drivers in your pc , so that why he install alcatel drivers if you want connect phone by usb then untick mark auto pin finding tick mark on usb mode select you job press run button when software said to put usb cable in phone then connect phone with usb if any problem then please post screenshot of volcano box |
01-29-2014, 19:22 | #5 (permalink) | |
Member: 1284113 Status: Offline Thanks Meter: 0 | Quote:
I tried to flash this phone with a new firmware but it had the wrong preloader...after that the phone cannot be seen by FLASHTOOL... I either need to use FORCE PRELOADER MODE but I do not know the test-point or maybe the Volcano box can write a new preloader to the flash memory and then I can use Flashtool to restore the phone.. The question is can I write a new preloader or a complete firmware (boot, cache, kernel, logo, recovery, system etc) to the phone using Volcano? If so how do I do this? Using P-05B cable on the box and some settings on the software? Thank you in advance. George PS: this is a great box and I hope I can learn to use it properly - I only bought it today and Im a bit lost... I regularly use Riff-box, Micro-box and other boxes but this one seems to be the king | |
01-29-2014, 19:30 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | for booting phone you can use modify cable this cable also help you to write perloader using flash tool ..no more Tp i tested and its work for me you can also try for pinouts just use Search button |
01-30-2014, 05:27 | #8 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | http://forum.gsmhosting.com/vbb/f723...cable-1643123/ Try with above cable And install these drivers Treiber_CynusT1_T2 And which window you are using |
01-30-2014, 11:05 | #9 (permalink) | |
BR, George edit: found these: http://d-h.st/2Hn... is it good? | |
02-02-2014, 21:42 | #10 (permalink) | |
