12-26-2013, 22:27 | #1 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1891184 Status: Offline Thanks Meter: 3 | china Mobile S7100 mini Format and Root problem..cpu 6820 i have one problem.i have mini s7100.it start and hang on logo. so i try to read the flash and also info work great and i got the flash file ...not pac format.the cpu is 6820 please look on the hang logo and also phone restart after 15 second After that i found the flash in the pac format in the forum with same flash id and name and so on...but the phone Name was different...when i try it using memory card then i got this error ....Signature verification failed... please look on the photo after that i try to Root and Format then i also got error please look on photo finally you can see the read info correctly.. please guide me what is the solution...because i can not format and i also can not get the pac file from phone and so on...so please guide me thank you |
01-02-2014, 05:26 | #4 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Did you try with Wipe on recovery mode ? If no 1st try wipe If not solved Just do format , If same flash with PAC file For file search on google Or find same working Phone Br AzimBahar |
01-02-2014, 19:34 | #5 (permalink) | |
Member: 1891184 Status: Offline Thanks Meter: 3 | Quote:
i also try to format but not successful...even that i also first read info and then try to format ...i did this technique but i get the same error he said...." Removethe cable and try again and read first and so on " please tell me any other solution thank you | |
01-05-2014, 23:44 | #9 (permalink) | |
i have connect the mobile to the pc. and start it in debug mode. like home button + vol down + pow then phone show these ports when i try to write then flasher just waiting for ports and nothing happening.. please tell me is this right way that i am doing and something diff thank you please have look on image | |
