04-14-2018, 08:35 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Coopad dazen 8297L-100 failed to flashing >>Current Task: COOLPAD>>Qualcomm>>Write Factory Files>>Select Factory Boot >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM50]. >>Status: 87 The parameter is incorrect. >>Reset the phone status(Ex:restart the phone),re-put the phone into edl mode and try again >>Ver:1.5.7 >>Current Task: COOLPAD>>Qualcomm>>Write Factory Files>>Select Factory Boot >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM50]. >>Hardware Id:007050e1 >>Selected Boot File is:H:\Msm laoders\Qualcomm bootloaders\Qualcomm_Factory_Loader_MSM8916_Cp.mbn >>Waiting for flash programmer to boot. >>Loading Build Info,Please Wait... >>Build Info Not Found. >>Size: 8Gb >>Done. Write modem Success. Write sbl1 Success. Write sbl1bak Success. Write aboot Success. Write abootbak Success. Write rpm Success. Write rpmbak Success. Write tz Success. Write tzbak Success. Write hyp Success. Write hypbak Success. Write misc Success. Write sec Success. Write boot Success. Write params Success. Write panic Success. Write system Success. Write persist Success. Write cache Success. Write recovery Success. Write userdata Success. >>Writing PrimaryGPT... >>Status: 13 The data is invalid. Write PrimaryGPT Fail. What to do now |
