Detailed Info. About Coolsand CPU !! http://www.volcano-box.com/teasing/2...1-voolcano.jpg Hi guys. i had seen many people having trouble about Coolsand ic. let me explain what is it and why is it. There is lot of Coolsand CPU and every CPU have Different Flash ic/BootLoader Our Team of Coders make almost All Coolsand Cpu Support but not all Flash Ic is Supported at the moment. Reason have not such phones in hand so can't Test. Cpu Which our Users Tested : Ct1128 ( Check This Successful Report by User ) CT1129D ( Check this Successful Report by user ) CT1130 ( here is Tested Report by User ) CT1131 ( Check this Successful Report By User ) CT1120 ( Check This User Successful report ) Ct8852D ( check this Success Report by User ) there is two type of Coolsand Cpu coming in these days. 1- Built-in Flash in Cpu 2- Non Built-in Flash in Cpu 1- Built-in Flash in Cpu Built-in Flash in cpu means Flash Ic is in Cpu. like CT1129D**. you will notice which phone have Ct1129D** have not any Flash Ic in Phone Board cause of it have Built-in! 2- Non Built-in Flash in Cpu Non Built-in Flash in Cpu means there is No Flash ic Built-in in CPU. like CT1128**. you can find Flash ic in mobile phone board Almost Every Coolsand Phone have it's BOOT just like HTC. SAMSUNG etc. and procedure almost same. if any HTC or Samsung you got with DEAD BOOT so mostly phone you can't repair with single Cable. what you do disassemble phone soldering wires and doing JTAG. as same if any Coolsand phone you got with DEAD Boot you can't repair it with Normal Way i mean with normal Rx Tx way. it have some special method that we did not Release it yet reason ? lot of and it's confidential..... At the moment We meet 4MB and 8MB Flash ic How to know which Flash ic is in mobile phone ? Simple Click on Read info you will get like this: >>Flash_size:0x800000 if you see this flash size this mean you have 8MB Flash ic. >>Flash Len :0x400000(4M) if you see this Flash Size this mean you have 4MB Flash ic. If you got phone with 8MB flash size then you must select FLASH TYPE: GQ25QL064 M36WOR6050U These Both are 8MB Flash ic if you got 8MB flash ic you have to select those Flash id and read flash/ Write flash etc.... if you got any error During Write Flash please open phone and check What Type of Flash ic it have if you have one of them then Your phone should be Hardware Problem and if You have any new type of Flash please open thread with title " New Flash ic Found " and post complete Details we will contact you ASAP and will try to Support it ASAP. If you got phone with 4MB flash size then you must select FLASH TYPE: EN71PL032 GQ25QL032 Built-in Ct1129D Built-in Ct8852D These Both are 4MB Flash ic if you got 4MB flash ic you have to select those Flash id and read flash/ Write flash etc.... If you got any error During Write Flash then open phone and check inside what kind of Flash ic you have. if you found any of above ic and you selected correct Flash ic then it Could be hardware or You have phone with DEAD BOOT. if you have phone which can READ flash but can't write or format like this; please press Power on/off button... Flash ID : 00C84016 Flash Type: SF_GD25Q32 Flash Len :0x400000(4M) >>Boot downloading complete! after this you can see Software Stop here ( Stop button Changed to Run ) This type of problem Could be you have Phone with Dead Boot and These are Useless. You can't repair it except try to Rehot/Reball MCU. I want to Tell you We successfully Done Ct1128 8MB format. This is Good for some user who are getting Wrong Code. ah!! for those who are getting wrong code. Please try to read Flash Exactly According to their Flash ic have after that try to find password from flash file. if still you got wrong password. you have two ways to solve it. 1- Take same working phone make sure Same Flash IC and Same MCU. read flash file from it and Write on Password Protected phone. For Emergency must take Full Flash as Backup and Much Take Dead Approval from your Customer. just for your Safety 2- Read Full Flash from password protected phone according to their Flash and make new thread and post complete details like MCU. Flash ID inside phone ( must check inside phone. Disassemble phone and Read inside Flash ic ). What Flash id you select. Readed Flash file etc.... we will try to find password and will tell you if we got. Some of user getting problem when they try to write Flash Erasing Start but stop at 37% 87% 82% etc.. These type of problem cause of Mobile MCU not 100% Good. can Reball and try again it will solve. There is some Coolsand Not Connected with RX TX they have USB Connectivity that type of phone Connecting on D+ and D-.... we will start on it pretty soon... i will Update it. if i got some thing else To be Continued... Br Faisal_Computer http://www.volcano-box.com/teasing/QQ20120611-1.png |
Faisal Bai Good work |
garat post bro all time u post good |
Very2 Nice Support,,,Keep Working Volcano Team,,,,,,,,,,;) ;) ;) |
thanks this is a good info u r a good manager ;) |
good info for us every day comes new solutions new problems but ? |
good work and great info |
thanks this is a good info u r a great |
FAISAL thank s 4 good information u say it Could be hardware or You have phone with DEAD BOOT. if you have phone which can READ flash but can't write or format like this; its mean all set r coming with dead boot then why show info read code read flash from dead only problem with writing is this possible phone conect with damage boot ? |
yes dead boot repair for coolsand most wanted if you add boot repair in next update volcano brings for me great fortune thanks |
i hav 8 coolsand cpu mobile like as gright 1130 ,ctfone 1130 ,nokia c1.all set read ok a almost erase ok but when when time to right they stop 1% or 2% . why .why not all set hardware problem. itried almost 12 set but not sucesssful.it is not all hardware faulty. unfortunately i am not able to single coolsand set repair day after day i returned to customers .because i am not successfull with volcono. |
press and hold power button whole working hope your problem solved |
An example for you If I gave you a book you remember it very well what will you do if I ask open 6th subject or tell me where is xxx subject for sure you will direct open it but if I gave you one book and damaged his 1st page where page numbers and subject list written and that book 1st time you have in your hand what will you do? For sure you will say don't as no information found As like this when it's write it must verify from starting address which phone damaged it will not format or write Hope you understand Br Faisal_Computer |
As like qaiser solve today one phone same problems as you told us with rehot mcu Also I have almost 30 phones which all are boot dead I success revive some of them as these phones just purchased for experiments and we success but solution is not we made for public Anyway you will day by day we will success in coolsand as you know it's long time awaiting..... Also a simple example there is lot of phones dead during unlocking ( zong Ufone etc) are all of them revive? Are all of them are hardware? Hope you understand Br Faisal_Computer |
