02-25-2015, 06:35 | #63 (permalink) |
Junior Member Join Date: Apr 2013 Location: india Age: 32
Member: 1920288 Status: Offline Sonork: amit raza Thanks Meter: 12 | Cool Samsung E1282T Flashing Steps: Samsung E1282T Flashing Steps: - Turn off your Samsung E1282T mobile phone and take its battery out. - From Flasher folder run ResearchDownload.exe program. - Click on Settings button. - At the opened window Select SC6530_SAMSUNG from Select Product drop down menu. - Select 921600 for Bautrate. - Select the following firmware files from the downloaded flash package: - For NOR_FDL: nor_fdl.bin - For NV: nvitem.bin - For PS: SC6530_sc6530_samsung_EricPlus_stone.bin - For MMICSC: mmi_res_128x160_csc.bin - Go to Calibration tab and uncheck them all, Then click OK button. - Click on Start Downloading button. - Now put the battery back into your phone. - Press and Hold OK key on your phone's keypad and connect USB cable to it. - The program will start the flash process automatically. - After the program finishes his job, Disconnect USB cable from phone. - With your phone on enter this code *2767*3855# - The above code will full reset your Samsung E1282T. - Now you can use your mobile phone the way you like. flasher-http://www.4shared.com/zip/zJVTqgIX/E1282T_ResearchDownloader_REV_.html file-forum.gsmhosting.com/vbb/f723/e1282t-original-samsung-flash-code-successfully-readed-volcano-1624624/ |
05-14-2015, 14:28 | #67 (permalink) | |
Insane Poster Join Date: Mar 2012 Location: india kolkata Age: 36
Member: 1740101 Status: Offline Sonork: 100.1641580 Thanks Meter: 11 | Quote:
bad file my handset is dead after flash this file | |
05-15-2015, 18:50 | #68 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | |
05-15-2015, 20:15 | #70 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Yes both are cable work well for this operation .. Just need to press boot key [Home key] while connect USB or when Finding pin with volcano main cable .. Wbr AniAXN |
06-12-2015, 07:17 | #71 (permalink) | |
No Life Poster Join Date: Sep 2012 Location: Tiptur- Karnataka, india
Member: 1809212 Status: Offline Sonork: 1000.2 Thanks Meter: 79 | thanks e1282t dead after flash with z3x, repair done with this process Quote:
thanks e1282t dead after flash with z3x, repair done with this process | |
07-05-2015, 08:13 | #75 (permalink) | |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Quote:
Repair it with Volcano according step by step manual in my First Post If You couldnt and if you are in Kabul I am in Fazli Market Koteh Sangi I will fix it for you . WBR | |
