09-09-2017, 07:09 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | E5573cs-322 unlocked successfully but data is not working help [ANSWERED] Code: Found modem : E5573Cs-322 Model : Huawei E5573 (untested) IMEI : 8617xxxxxxxxxxxx Serial NR. : DGF7S17310004933 Firmware : 21.323.01.00.306 Dashboard version : WEBUI_17.100.15.05.306_MRE5 Web UI version : WEBUI_17.100.15.05.306_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) Code: Found modem : E5573Cs-322 Model : Huawei E5573 (untested) IMEI : 000000000000000 Serial NR. : 0123456789ABCDEF Firmware : 21.323.01.00.306 Compile date / time : Jan 20 2017 20:44:37 Hardware ver. : CL1E5573CSM11 Ver.B Dashboard version : WEBUI_17.100.15.05.306_MRE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) Code: Found modem : E5573Cs-322 Model : Huawei E5573 (untested) IMEI : 8617xxxxxxxxxxx Serial NR. : 0123456789ABCDEF Firmware : 21.323.01.00.306 Compile date / time : Jan 20 2017 20:44:37 Hardware ver. : CL1E5573CSM11 Ver.B Dashboard version : WEBUI_17.100.15.05.306_MRE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) received and sent both failed. any solution? |
09-10-2017, 07:43 | #3 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | i searched a lot but as i guess (21.323.01.00.306) it is the only latest version. if you have the link then plz give me. thanks as you can see above sn no. is also damaged after unlock. now i am reparing the sn but it's giving error. please see below. Code: >>Current Task: HUAWEI>>Serial Repair >> >>Current Port: FC - PC UI Interface (COM104) >> >>Repair Serial Info: Ser-Nr.:DGF7S17310004933 >>Repair Serial Result: +CME ERROR: 1 |
