Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 01-28-2013, 07:42   #1 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
Thumbs up nokia x2-02 .....
i have nokia x2-02 after formatting no service or same time searching .
before formatting set working slow .other phone working fine
and after flash with phone backup same problem no service and searching
plz help me about that problem
Old 01-28-2013, 07:59   #2 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
not possible if u r fone is ok than why u formate it give us full detail
Old 01-28-2013, 08:03   #3 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
brother before formatting phone working slow i make rest factory then same .and then i formatted with volcano box after formatting phone goes to no service and searching .
and then i flash the the phone back set same condition no service and searching.
Old 01-28-2013, 08:09   #4 (permalink)
Member: 1842527
Thanks Meter: 40
1 bro chang imei no
2 Chang pa filter Ur problem 100 solved
Old 01-28-2013, 08:13   #5 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
Originally Posted by gk8888 View Post
1 bro chang imei no
brother i change the imei but same and before formatting PA is ok whats problem with formate its not a PA problem
Old 01-28-2013, 08:23   #6 (permalink)
nomi_42us's Avatar
Member: 500844
Sonork: 100.1680109
Thanks Meter: 285
also faced same probelm tomarrow but luckily i had readed its full flash before format. so i wrote it back and phone worked and i returned it to customer with previous fault. (phone was hanging before format after format hanging problem was solved but phone gone to searcing mode. and when i write back readed flash file phone started hanging problem but signals were perfect.)
Old 01-28-2013, 08:30   #7 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
brother i have full backup of phone write it but not done
Old 01-28-2013, 11:15   #8 (permalink)
nomi_42us's Avatar
Member: 500844
Sonork: 100.1680109
Thanks Meter: 285
your luck.. in my case it worked to retrieve phone to previous stage.... i think its a bug after formating phone goes to serching.. when you power on phone after formate check on display you will also see a error on phone like "rf value set to default"... am i right?
Old 01-28-2013, 12:31   #9 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
no any error brother
br
.::Mustafa::.
Old 01-28-2013, 15:30   #10 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
br
.::Mustafa::.
It's NV Data Problem Common In Coolsand Team Is Working On This Issue I Hope Team Release Soon.
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 01-28-2013, 15:39   #11 (permalink)
zubair pathan1's Avatar
Member: 1867883
Sonork: 100.1654594
Thanks Meter: 27
bro its hardware problem change transmeeter ic
Old 01-28-2013, 21:59   #12 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
after format or reset is software problem , it solved on writ by good working same id file , soon nv date read write option suported on volcano box then no need to flash the phone
Old 01-29-2013, 08:51   #13 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
Thanks to all my problem is solved i back the phone same condition ............and return to customer.
br
.::Mustafa::.
Old 09-16-2013, 07:42   #14 (permalink)
abdul kadhar's Avatar
Member: 651994
Sonork: n/a
Thanks Meter: 62
nokia x2-02 hang then software done but still hang problem pls help
Page generated in 0.26410 seconds with 8 queries
