05-07-2015, 11:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Uttar Pradesh India
Member: 656277 Status: Offline Thanks Meter: 187 | forme M60 plus dead by volcano i readt it's flash file after unlock code show code but set dead i tried to flash by read file but hang on writing 0 % i tried with diffrent baund rat but same Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00C8006000160000 Flash Type: SF_GD25LQ32 Size:0x400000(4MB) Reading completed. The data has been saved in C:\Documents and Settings\Nitish Sharma\Desktop\_20150507_154731_FullFlash.bin, size: 4 M. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM123), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00C8006000160000 Flash Type: SF_GD25LQ32 Size:0x400000(4MB) >>Writing...(0) plz help me |
05-07-2015, 13:06 | #2 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | which version u use? try to format it if failed then find same working flash file and flash it but before try with ur bakup file to write it back by different volcano version 2.7.2 |
05-07-2015, 15:14 | #4 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hello .. Use Volcano 2.7.2 version .. Follow this step ..
Insert Buttery & Press power key 1-2 minute .. Post result .. Wbr, AniAXN |
05-08-2015, 11:41 | #5 (permalink) | |
Member: 656277 Status: Offline Thanks Meter: 187 | Quote:
i tried with volcano 2.7.2 ver. read & formate only not write in writing same hang plz guide m | |
05-10-2015, 09:46 | #7 (permalink) | |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
Volcano Don't Have a issue With SPD 6531 ... Read Carefull !! Always Read Backup and Select Readed File and Format Phone after Format Power on With Volcano Eagle Eye ... Press Power Button to 1 to 2 Minutes Until phone get Power on See My Personal Thread and See All Volcano Versions are Working With SPD 6531 Success ..! No Failure http://forum.gsmhosting.com/vbb/f723...ofash-1942579/ | |
05-10-2015, 09:52 | #8 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | For me i always use high baud rate press boot key even using modified cable(don't know boot key then use normal cable check one by one with button to find boot key) use direct usb cable |
05-16-2015, 05:49 | #9 (permalink) | |
sir i formate this phone but same dead after it i want to write but hang Connection successful,connected state! Version: V3.8 SN: Port:COM127 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. please detect pinouts and defined pinouts first. please detect pinouts and defined pinouts first. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... Found: D+ = 3, D- = 2, USB_VCC = 1 10 Detection D+/D- with 0.98 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Detection completed. Setting pinouts... Find USB device:SPRD U2S Diag (COM128), (VID_1782&PID_4D00) Pinout setting complete. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM128), (VID_1782&PID_4D00) Available Ports:COM1 COM127 COM128 Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00C8006000160000 Flash Type: SF_GD25LQ32 Size:0x400000(4MB) >>Writing...(0) plz help m | |
05-16-2015, 06:34 | #10 (permalink) | |
Try Same Other Good Working Phone Read Flash And Write Your Fault Device !! | |
05-17-2015, 04:53 | #12 (permalink) |
Member: 1445819 Status: Offline Thanks Meter: 4,976 | in Case Phone CPU's are Getting Heat at Read Flash .. If Your Phone Have a Any Short Set Will Be Dead Possible .. Not Only Volcano.. Any Tool Can Kill Your Phone !! Try to Write Same Other Good Working Read File and Post Results ... |
05-17-2015, 05:28 | #13 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Hello bro you are connecting phone and box on higher com port . plz reduce it to lower number ,sure you will get success .Try and post result . |
05-18-2015, 05:11 | #14 (permalink) | |
try but same bro. Detection initiated... Found: D+ = 3, D- = 2 Detection D+/D- with 3.97 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Detection completed. Setting pinouts... Find USB device:SPRD U2S Diag (COM6), (VID_1782&PID_4D00) Pinout setting complete. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM6), (VID_1782&PID_4D00) Available Ports:COM1 COM6 COM127 Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00C8006000160000 Flash Type: SF_GD25LQ32 Size:0x400000(4MB) >>Writing...(0) | |
