Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 02-19-2013, 10:52   #1 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 137
Gfive W8 Dead
Gfive W8 problem was emergency so search for file but not found so I flash Gfive w5 flash file and set go dead so try to write original file but it failed to flash and this error come
I try by changing all Flash Type but still same also try Boot_B
Here is flash log of backup original file because no save screen shot
2013-02-18 7:45:49 AM >>Start program...
2013-02-18 7:45:49 AM >>CPU ID: 880A 7002
2013-02-18 7:45:50 AM >>Flash ID : 001C3817
2013-02-18 7:45:50 AM >>Flash Type: SF_EN25S64
2013-02-18 7:45:50 AM >>Flash Len :0x800000(8M)
2013-02-18 7:45:50 AM >>Reading...(0)
2013-02-18 8:04:31 AM >>The data has been saved in
Old 02-19-2013, 11:17   #2 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,212
Select Boot_Auto from boot
Select RDA 8853A from flash type
try to write ur file
post result with screenshot
br,
azam
Old 02-19-2013, 11:27   #3 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 137
I already said that I try with all Flash Type one by one. Here is try again by your instruction
Old 02-19-2013, 11:29   #4 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,357
try with 1.8.5
and select 8853b-sp18m and write backup
Old 02-19-2013, 11:40   #5 (permalink)
Member: 505794
Thanks Meter: 2,212
@ wsw243
Don't take tension bro
download v 1.8.3 or later & try again with ur bakup file bro
Download from here https://hotfile.com/list/2146352/c6f232d
br,
azam
Old 02-19-2013, 13:24   #6 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 137
ver 1.8.5 also failed it even not detect CPU ID
Old 02-19-2013, 14:13   #7 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,357
Try to change flash ic if not flash is in phone then CPU is damage
Old 02-19-2013, 15:36   #8 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 137
before flash wrong file i do these without problem
Read Info
Format
Read Flash
but after flash it has this problem so there is no reason of hardware problem. Maybe volcano need to fix this bug. Mostly Product Supporter is from my city so they can pm me their address so I will visit to them shop to test and fix it.
Regards
Old 02-19-2013, 19:09   #9 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,357
only Qaiser is form fsd and me too , connect with me , sent me pm your shop address and phone number
i try to solve your problem
Old 02-19-2013, 19:49   #10 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,877
what's Ur Backup Size?
Select CPU RDA 8853A & increase time delay Like 1000
then Do Write Flash
Try & Post Result With Screen Shot.
If your Problem Not Solved then contact with me
Qaisar Mahmood
Old 02-20-2013, 02:39   #11 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 137
Backup size is 8MB and wrong flash file size is also 8MB. Already try with increase time still same here is screen shot of again try
Here is ss of latest ver
I try all my best possible now only way you do it yourself. PMing u both who will near me I will visit to his shop
Old 02-20-2013, 03:48   #12 (permalink)
ravipal_82's Avatar
Member: 1194176
Thanks Meter: 203
dear support team i am not spam here and not say whch box is best or not best but bugs in coolsand tab so plz solved it i also suffering same problem i have read the backup with volcanoo box but when i have wite this backup file with other box my handset is on but when write with volcanoo not power on after formate and long press of power button my handser is w5 g-five coolsand cpu
and mr wsw24 try with other box an write backup if u have to read file with rda 8853a cpu
Old 02-20-2013, 04:19   #13 (permalink)
***MALIK***'s Avatar
Member: 556396
Sonork: 100.1609417
Thanks Meter: 340
1.use version 1.8.3
2.use rx tx cable
3.write backup if u have
4.write flash with another working set flash file.
Old 02-20-2013, 04:23   #14 (permalink)
samo_d1's Avatar
Member: 1483881
Sonork: 100.1612698
Thanks Meter: 92
first of all
read flash file with new boot b and select flash type auto
then make rar file of your readed flash file
and check rar file size .. file size will be around 2 mb
if file size 2mb after making rar.. write it .. your phone must be power on..
if file size in 1 kb or 2kb. after making rar .. your backup is not good
after writing this file your phone will be dead ( becuase you did not read file currectly )
br
samo_d1
Old 02-20-2013, 04:58   #15 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,357
I do not know why people cry . I daily done many phone of coolsand
I already done many time done gfive w5
No problem
Page generated in 0.50300 seconds with 8 queries
