Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 04-20-2017, 09:20   #1 (permalink)
Member: 2420663
Thanks Meter: 22
Exclamation mtk.exe cant start(SOLVED)
hi guys need help for my volcanobox cant run inferno it say access violation at address 00000000. Read of address 00000000.I can access volcano tool and utility just fine.
i just format new fresh window 7 ultimate service pack1 64bit.
and i need to use the inferno..please help me
screenshot:
Old 04-20-2017, 09:28   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
screenshot:
Download setup again and re-extract the setup
Make sure antivirus should be disable or Inferno should be in exception list of your antivirus..
Old 04-20-2017, 11:04   #3 (permalink)
Member: 2420663
Thanks Meter: 22
Exclamation
already did that still same...and my computer dont have antivirus yet...really need help here..is it because 64bit?
before that problem came it have error msvcr100.dll problem than i download that dll and problem solved and another problem occurred,,msvcp100.dll is missing problem,so i download that dll and problem solved and than the last one is this access violation thing came out..i dont know how to fix this one..
The Following User Says Thank You to dummytest97 For This Useful Post:
Old 04-20-2017, 13:23   #4 (permalink)
ij_cell's Avatar
Member: 1937038
Sonork: QQ 2045657399
Thanks Meter: 4,492
Install ITUNES into your system it will work like charm
BR.
Sehar
GPG Team
The Following 3 Users Say Thank You to ij_cell For This Useful Post:
Old 04-21-2017, 08:50   #5 (permalink)
Member: 2580379
inferno error please give me solution
please do not use any software to run inferno or n to crack inferno
Old 04-21-2017, 09:57   #6 (permalink)
ij_cell's Avatar
Member: 1937038
Thanks Meter: 4,492
Un-install debuggers and sniffing stuff from your system like total commander,flexy-hub,usb re-director and such software and run again INFERNO tool.
BR.
Sehar
GPG Team
Old 04-22-2017, 03:54   #7 (permalink)
Member: 2420663
Thanks Meter: 22
Exclamation
BR.
Sehar
GPG Team
this method really works like charm..like u said..i dont know why what related between itunes and inferno..
Old 04-22-2017, 03:56   #8 (permalink)
Member: 2420663
Thanks Meter: 22
Exclamation
i dont use any crack software im using legal volcano box..
and what is N ??
a program?
Old 04-22-2017, 05:59   #9 (permalink)
ij_cell's Avatar
Member: 1937038
Thanks Meter: 4,492
Few graphic issue related with 64bit system mostly.
and what is N ??
a program?
Re-check again what you have been installed on your system,Something still there which is making conflict with our security.If possible clean and re-install new OPERATING system for solve this issue.
BR.
Sehar
GPG Team
Old 09-12-2018, 14:01   #10 (permalink)
Member: 1580193
Thanks Meter: 22
fix the problem i test 3 comuter sam problem
Old 09-12-2018, 14:53   #11 (permalink)
Member: 1718440
Thanks Meter: 620
Nothing to fix. It's working perfectly.
Old 09-13-2018, 17:48   #12 (permalink)
Member: 2455995
Thanks Meter: 3
inferno don t open i need remote support i buy the renove in january and i don t use,I could use 2 or 3 times in another pc,and then the same mistake...
correct the dongle launch bug
Page generated in 0.23486 seconds with 9 queries
