09-26-2014, 21:32 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hi ... Kindly Post Screen shot with PHONE Detect Logs .. Can you work with RX or TX ..? Post allows details ... Wbr, AniAXN |
10-01-2014, 10:58 | #3 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 579284 Status: Offline Thanks Meter: 6 | find sir find the screen shot and guide me Volcano Updated: 2014-09-16 Connecting... Connection successful,connected state! Version: V3.8 SN:000-002-318 Port:COM123 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Connecting... Connection successful,connected state! Version: V3.8 SN:000-002-318 Port:COM123 Connecting... Connection successful,connected state! Version: V3.8 SN:000-002-318 Port:COM123 Available Ports:COM1 COM123 Detection initiated... Vcc: null Gnd: null Analyzing D+ and D-... Failed to detect. >>Pinouts are not fonud! |
10-01-2014, 12:01 | #4 (permalink) | |
Freak Poster Join Date: Oct 2013 Location: Central Igorot
Member: 2041408 Status: Offline Thanks Meter: 38 | Quote:
if your cable is good, then you can measure the voltage output if enough connect your positive and negative line to a multimeter then on spd tab click on RUN, see if the multimeter show up voltage at least up to 5v. fluctuation. if then something on your box. but check cable 1st or your phone must not at dead condition. | |
10-03-2014, 00:19 | #7 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hi ... If your Box in Under Warranty ... Connect your Retailer ... If not follow this link - http://forum.gsmhosting.com/vbb/f723...ssing-1800996/ Wbr, AniAXN |
