07-12-2018, 13:59 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bamako Mali
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | Help me Asus X00AD FRP solution with Unitool I tried with inferno unitools without succes here is log >>Current Task: ASUS>>Qualcomm>>Clear FRP>>Select Factory Boot >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM66]. >>Hardware Id:007050e1 >>Selected Boot File is:C:\Users\D\Desktop\flasher\Qualcomm_Factory_Loa der_MSM8916_Asus.mbn >>Waiting for flash programmer to boot. >>Status: 21 >>Get Partition Info Fail.Please select boot file from factory firmware and try again If someone can help me to remove it. Thank to all |
07-12-2018, 14:33 | #2 (permalink) |
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | Solved Put phone in FASTBOOT mode VOL+ and POWER Open Unitool ADB&FASBOOT tab chose REMOVE QUALCOM GENERIC FRP Here is log >>Ver:1.6.1 >>Current Task: Tools>>ADB Fastboot RsTools >>Remove Qualcomm FRP... >>If stuck here more than 1 minute,check phone connect to computer in right mode >>Remove Qualcomm FRP Success |
