12-24-2014, 11:44 | #3 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | USB MODE: 1- Put Mobile into FTM mode How to enter FTM mode? A: Power off phone B: take Battery off C: Insert Battery D: Press & Hold Volume down and Power button Together till mobile comes into FTM mode 2- After FTM mode insert Original USB cable in mobile 3- Install Drivers ( Drivers can found from install folder Drivers\Zte Unlock Drivers\ZTE_Handset_USB_Driver) 4- In device manager you can see installed Com port of ZTE phone with name “ Zte handset diagnostic interface (DFU) “ 5- Open VolcanoBox software 6- Go to Zte Tab 7- Select Com port of Zte handset diagnostic interface (DFU) AND DO YOUR OPERATION. |
The Following User Says Thank You to rehansk8879 For This Useful Post: |
12-24-2014, 17:31 | #7 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Algeria
Member: 1263652 Status: Offline Thanks Meter: 42 | Code: Detection initiated, connect the phone and power on it... Vcc: null Gnd: null Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... Failed to detect. >>Pinouts are not fonud! |
12-24-2014, 18:22 | #9 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hello ... Can you plz change battery negative or positive points ... & Try again on that way ... Wbr, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
