12-23-2013, 12:40
#2 (permalink)
Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508
Sonork: 100.1593820 Thanks Meter: 11,978 | Quote:
Originally Posted by AEK@GSM what is the procedure for unlocking lt18i | Use Help Option Quote:
ow to Install Drivers for NON Test Point Models:
1. Go to X10 DRIVERS
2. Select the correct 32 bit or 64 bit shortcut folder for your Operating System
3. First run "SEMC Flash Driver Install"
4. Complete the install wizard that appears
5. Second run "ADB Driver Install"
6. Complete the install wizard that appears
7. Next we need to connect the X10 in Flash Mode (some times called boot mode)
8. Remove the battery for 10 seconds and replace
9. With the phone still powered off, Press & HOLD the "Back Button"
10. Still holding the Back Button connect the USB cable
11. Windows will now detect the new hardware and automatically install the drivers.
12. Once complete, remove the USB cable from the phone and power the phone on.
13. Next we will connect the phone with "USB Debugging" Enabled
14. On the phone go to "Settings"
15. Next go to "Applications"
16. Next go to "Development"
17. Now enable "USB Debugging"
18. Click "OK" to confirm enabling of USB Debugging
19. Now connect the USB cable
20. Windows will now detect the new hardware and automatically install the drivers.
21. Once complete you can proceed to unlock your X10, X8 etc...
Follow Instructions on Screen.
Now we can proceed to Unlocking the X10, X8, etc...
1. Now click on the "SE" tab of the software
2. Please make sure SIM card is removed from the phone
Please make sure SD card is inserted in the phone before unlock !!!!!!!!
3. Make sure that your phone is running a later version of ANDROID that 1.6 (tick the box to confirm on the Unlock
| Br
AzimBahar |
