11-10-2012, 06:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: IN THIS WORLD Age: 44
Member: 49594 Status: Offline Thanks Meter: 39 | Help repair imei samsung i9100g using latest ver of volcano tool Code: Connecting, Please Wait... Found Device...0C8A002400000001 Model = GT-I9100G OS Version= 2.3.6 CPU TYPE = t1 CPU TYPE 2= GT-I9100G Model= GT-I9100G Device Info 1= GT-I9100G Display ID= GT-I9100G SIM NOT INSERTED PLEASE INSERT SIM FIRST. GT-I9100G IMEI 1= null IMEI 2= Can't find service: iphonesubinfo2 Running data do not touch phone... Please Switch off device and switch on again?? Waiting for device to connect... Rechecking Imei Found Device...0C8A002400000001 IMEI 1= null IMEI 2= Can't find service: iphonesubinfo2 Write IMEI done, reboot please. >>================================== super boy24 |
11-10-2012, 09:43 | #4 (permalink) |
Freak Poster Join Date: Oct 2010 Location: jamnagar(gujarat)india Age: 33
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | wait ! i give you a file just use it to restore imei , then use volcano box and change imei ! but you need your set to be rooted. |
11-10-2012, 12:48 | #8 (permalink) |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | I9100G samsung Original imei repair solved by volcano with tutorials yes model supported do it! ill give you tutorial for this here is step by step solution just do it carefully image step 1 / step 2 / step 3 just do it carefully good luck hope you solve your problem ! press thanks if you like my work! |
11-10-2012, 13:36 | #10 (permalink) | |
Member: 49594 Status: Offline Thanks Meter: 39 | Quote:
Code: Model Selected : GT-I9100G Selected IMEI for Repair :358401046072581 Phone Found. Phone DATE : xð~CDMG Phone model : G ERRO Phone product code : Phone version : -CDMG ERRO/ Phone Imei : IMEI Repair Started... Scaning Security Area... Sorry Model not added for security reading. Unsupported phone or version...GT-I9100G/xð~CDMG / Fail to Unlock Phone security can not bypass. >>=============================== super boy24 | |
11-10-2012, 14:39 | #11 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: attock Age: 35
Member: 1147735 Status: Offline Thanks Meter: 156 | Quote:
after unlock imei mismatch on back cover samsung i9300 rood with odin 1.85 cf boot 6.0 how to change imei i have only z3x and volcano box plz help me sir urgent here is very tension i try this solution but error No phone found. - Please Try again make sure phone connected. | |
05-18-2013, 10:38 | #13 (permalink) |
Registered User Join Date: Jan 2010
Member: 1221313 Status: Offline Thanks Meter: 263 | Volcano Updated: 2013-04-13 Connecting... Connection successful,connected state! Version: V3.8 SN:249-917-925 Port:COM28 After format or Flash you have to press & hold power button for at least 1.30 mins. For this phone only read info and reset user code active. For "Read Info" button , select phone modem or use rj45 cable. For unlock need to enable ADB. For "Read Info" button , select phone modem or use rj45 cable. For "Pattern Unlock" button , select phone modem or use rj45 cable. Version over "4.X.X is not supported for pattern unlock. Model Selected : GT-I9100 CDMA Reading Phone Info... No phone found.. - Please Try again make sure phone connected. =============================== Model Selected : GT-I9100 CDMA Reading Phone Info... No phone found.. - Please Try again make sure phone connected. =============================== Model Selected : GT-I9100 CDMA Reading Phone Info... No phone found.. - Please Try again make sure phone connected. =============================== Model Selected : GT-I9100 CDMA Reading Phone Info... No phone found.. - Please Try again make sure phone connected. =============================== Unable to open COM19 =============================== Model Selected : GT-I9100 CDMA Reading Phone Info... No phone found.. - Please Try again make sure phone connected. =============================== Model Selected : GT-I9100 Reading Phone Info... No phone found. - Please Try again make sure phone connected. >>=============================== |
