01-12-2015, 22:13 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | How can I detect pinouts of Micromax X600 in Volcano ? Can anyone give me the solution with still image of how can I detect pinouts of Micromax X600 in Volcano using Volcano 05B Jig supplied with the box ? BR, amit123 |
01-12-2015, 22:33 | #3 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Thanks for your reply Umesh Ji. But why I cann't detect this MICROMAX X600 phone using Volcano 05b jig ? What the other way ? The phone doesn't have any problem inside though! Please answer me ! |
01-13-2015, 10:03 | #5 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Your image size is too small we can see it any way use this jig connect rx tx as shown in umesh image you can also flash this mobile via usb cable uncheck pin finding select usb mood press run and then insert usb cable powered of mobile battery inside some cases need to press boot key . |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
01-13-2015, 21:46 | #6 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Hi Akhtar Ali Jatt, I have used Jig P-05B supplied with volcano and followed the above steps for USB flashing keeping battery inside and then inserted the jig but no response ? Is MICROMAX-x600 ANDROID or Simple? Please write in steps? Advance thanks, Br, amit123 |
01-14-2015, 06:43 | #7 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | As i know it's mtk 6235 & it's not android , you can flash it via usb on box cable ( need to set pinout in detect tab ) or direct usb cable from pc to mobile with battery inside just follow above method you can also sold rx tx and can do your work . |
01-14-2015, 07:29 | #8 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | Quote:
this phone not detect usb or tx rx method with 05b jig solder tx rx in mobile pcb with universal jig thread close br umesh gaba | |
