01-04-2015, 23:43 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | How can I detect & Read/Write etc. Micromax A069 Kit Kat Version 4.4.2 with Volcano ? Could you give me an image or video solution of "How can I detect & Read/Write etc. Micromax A069 Kit Kat Version 4.4.2 with Volcano ?" I tried to detect the "D+,D-, VCC & GND" with the Jig 05b supplied with Volcano Box with different option but failed to detect every time? Your exact solution of how to detect and the next step's Read/Write etc. either with image's or video shall be highly solicited? Advance thanks to all, Thanks & Best Regards, amit123 |
01-05-2015, 04:41 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | Hi, when mobile is detecting You Need to Press Volume down Key for make boot. Its Mtk 6572 Cpu.Easily Work with volcano. For Read,write and format. open android tab> select usb mode>select mtk android then you can do your job( read ,write,format ,imei,read info etc,) If you face any problem then make Screen Shot.and post it. BR |
01-08-2015, 13:24 | #3 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Hi Laxmi Kamlesh, I tried accoding to your trick but did not succeed ! Should I first go to the "Detect" tab of "Volcano Box 2.5.0" version software and try to detect ? Actually, I tried to detect it using different skills but didn't detect at all ? And when I go to the Android --> Tab Section, I am using Volcano "5b Jig" supplied with the box but it never asked for driver and nothing happened actually ? How should I go from starting to end? I want to copy the flash file of the phone. There is no fault in the phone. Please upload the box still picture of how to go ahead from starting to beginning ? |
01-08-2015, 14:49 | #4 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hello .. If you use Android tool .. ! That time you can use Normal USB cable Direct from PC .. Just Do This Step .. Run Latest Volcano Android Tool .. Select like pic bellow .. After Press Start when software say analysis USB .. Insert Buttery & plug USB cable to Phone .. Just plug USB ..for MTK chip no need to press any boot key .. If face any problem make screen shot & post result here .. Wbr, AniAXN |
