04-06-2016, 18:19 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | How to connect Mstar internally? [ Answered ] Amy idea what pins are used for connecting via usb I don't see any usb test point in the phone I can read gnd. Tx, rx, dp, de Thanks Enviado desde mi SM-N920T mediante Tapatalk |
04-06-2016, 23:11 | #2 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | RX TX Method Not Work For MSTAR... Use Volcano Main Module Go To Detect Tab Select Mstar Connect Phone With 05B Jig N Try To Detect Phone.... Br. Hi-Tech Care GPG Team |
04-07-2016, 06:57 | #3 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hi not a newbie here, it is clear mstar only conects via USB, but I saw a thread where they connected a mstar phone via internal pinout, thats why I ask, maybe there is any special combination of TP, which enables USB connection vi internal TPs. |
04-07-2016, 08:03 | #4 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
If USB Jack/Connector Damage U Can Use Phone DP DM Point For Detect If Having In Phone. Note :- Some Handset Require Battery Some Not In Mstar So Check With Both.... With & Without Battery Br. Hi-Tech Care GPG Team | |
04-07-2016, 13:36 | #5 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
I will try with these 2 points. For some reason it is not getting detected via usb port, maybe is damaged. It is a one row 12 pins port, so magic usb doesn't applies here. Thank you Enviado desde mi SM-N920T mediante Tapatalk | |
04-13-2016, 19:44 | #7 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hi, thanks for your support Here are the images Code: http://yurais.com/20160413_105505.jpg http://yurais.com/20160413_105712.jpg http://yurais.com/20160413_105730.jpg Enviado desde mi SM-N920T mediante Tapatalk |
04-15-2016, 02:54 | #9 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Ok i will try connecting a USB cable. What i did before these tipswas connecting d+ d- and gnd, but never tried with vbus. Will comment tomorrow Enviado desde mi SM-N920T mediante Tapatalk |
04-15-2016, 06:52 | #10 (permalink) | |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Quote:
VBUS=Usb +5 volts important to connect D+=Data plus important to connect D-=Data minus important to connect GND=Ground important to connect These 4 connections should be connect to device for work out | |
The Following User Says Thank You to ij_cell For This Useful Post: |
