06-03-2014, 08:24 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 775567 Status: Offline Sonork: tybsky Thanks Meter: 59 | how to do format after showing data fail ?? Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00EC00BC00555400 Flash Type:[SAMSUNG] K9F4G08/K9K4G08 FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),1536k(2ndbl),256k(params),512k(vmja luna),10m(modem),3840k(fixnv),3840k(backupfixnv),5 120k(dsp),3840k(runtimenv),10m(boot),10m(recovery) ,270m(system),109m(userdata),60m(cache),256k(misc) ,1m(boot_logo),1m(fastboot_logo),3840k(productinfo ),512k(kpanic),512k(simlock),10m(intmemory) >>Analysis flash internal data fail. |
06-03-2014, 12:49 | #2 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | not supported flash ic format will risky so do format at your own risk |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
06-03-2014, 12:50 | #3 (permalink) |
06-03-2014, 18:17 | #4 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | @ techtogsm .... Not Support Flash Chip ... Don't Format the Phone .. You Need PAC File To Write On it .. Br, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
06-04-2014, 08:46 | #5 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Quote:
If it gives message - "Analysis Flash internal data Successfully" then you can do format without any risk. If it gives message - "Analysis Flash internal data fail" then its risky to format the phone (Do format on your risk.) How to Format..See here - *Remove phone from USB Cable. *Format your device (Tick "Format" & press start) *Power OFF phone, insert battery and then insert usb cable. (If not detected, press volume up/volume down while inserting usb cable) *Handset will get formatted...check now Format only if you have working backup or firmware available at your collection. bR. Smk | |
The Following User Says Thank You to Moiz Khan For This Useful Post: |
