09-13-2014, 10:48 | #1 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | How To Enter Recovery Mode Using Shift Mode on Volcano .. How To Enter Recovery Mode Using Shift Mode By Volcano Just Enter Factory Mode any Spd or MTK Android Connect USB Cable Phone will Connect via ADB Run Volcano & Go ADB Mode Now Phone Come on Recovery Mode Wbr, AniAXN |
The Following 9 Users Say Thank You to AniAxn For This Useful Post: |
09-13-2014, 11:20 | #3 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1682611 Status: Offline Thanks Meter: 3 | [IMG]http://i.*****.com/jEniKED.jpg[/IMG] nable to connect to the device, make sure the device is properly connected, USB debugging is turned on. Unable to connect to the device, make sure the device is properly connected, USB debugging is turned on. Unable to connect to the device, make sure the device is properly connected, USB debugging is turned on. Available Ports:COM1 COM12 Current Port:COM12 Unable to connect to the device, make sure the device is properly connected, USB debugging is turned on. Unable to connect to the device, make sure the device is properly connected, USB debugging is turned on. >>Unable to connect to the device, make sure the device is properly connected, USB debugging is turned on. |
The Following User Says Thank You to dinh11 For This Useful Post: |
09-13-2014, 16:46 | #7 (permalink) | ||
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
You Can Do Wipe Data .. But You Loss User Data .. Quote:
Just you Know How to Enter That Mode.. Wbr, AniAXN | ||
The Following User Says Thank You to AniAxn For This Useful Post: |
09-27-2014, 11:31 | #8 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1892139 Status: Offline Thanks Meter: 56 | can you please tell me how to enter factory mode/recovery mode for SPD android phone..because many SPD phone I try with button combination always failed...that is why I always use volcano for formatting SPD android phone..SPD android phone only Last edited by AniAxn; 09-27-2014 at 13:41. |
09-27-2014, 13:49 | #9 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Not all spd phone will enter Factory mode by same proses .. Try with both vol key or home key with power key ... Wbr, AniAXN |
09-29-2014, 12:28 | #10 (permalink) | ||
Member: 1892139 Status: Offline Thanks Meter: 56 | Quote:
definetly not ALL..thanx for answering and supporting BR JAVA rapopo | ||
